Step 4Theory of Operation
The device does whatever it can to keep the OUT pin exactly 1.2V higher than the ADJ pin. For example, if ADJ is shorted to ground, then OUT is 1.2V. In this application, we have connected a 1 ohm resistor from OUT to ADJ, and connected ADJ to the car battery. If the battery is 12V, then OUT pin of the LM317 is 1.2V greater, or 14.2V. Because there is a 1 ohm resistor from out to ADJ (and car battery), and there is 1.2V across this resistor, therefore 1.2A flows per ohms law
V = I * R ===> 1.2V / 1 ohm = 1.2A ( a bit of algebra here)
The LM317 will perform exactly as described as long as the following conditions are met:
- the input voltage of the LM317 must be about 1.5V greater than the OUT pin
- The LM317 does not overheat and go into self protection mode (hence the heatsink)
comment
Add Comment
Add Comment
