Car / Motorcycle or Bicycle Wireless 2.4ghz Alarm Range 500m 10$ Budget
12,410
247
14
Published
Introduction: Car / Motorcycle or Bicycle Wireless 2.4ghz Alarm Range 500m 10$ Budget
this is easy and inexpensive wireless alarm with 200m range if module is insert inside car or >500m if module is outside
two modules: RX and TX
receiver module make sound alarm and led blink when detect signal
transmit module is connect to any device or switch to turn it on
Hardware is arduino attiny85 and nrf24l01, very inexpensive!
In attached files to be printed in 3d for RX and TX case
PCB module is editable with fritzing
http://fritzing.org/home/
you can make this single face PCB with cnc or transfer method
http://fritzing.org/projects/car-motorcycle-o-bicy...
attiny85 is easy to program with arduino nano or uno with this guide
RX/TX modules are powered with 9v battery but you can use any DC power with 5v to 20v voltage without problem.
For car alarm i suggest to use car inside lights to be activated with the opening of the doors.
example
this module can send code of alarm so it can be used as alarm for the house by inserting it in the doors, windows or putting in series with sensors (gas, fire, infrared)
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    14 Discussions
    I'm puzzled there are 2 ino files,one for receiver,another for transmitter.so do i need to program two attiny chips or burn these two files in one chip.
    receiver 1 x attiny85 with receiver program and 1 x nrf24l01
    transmitter 1 x attiny85 with transmitter program and 1 x nrf24l01
    Hello, I can not operate the receiver with an ATtiny84. I put a LED on pin 13 (D10) but not blinking.
    Thank you...
    Hi, looks nice.
    However, not that I am an expert or that it changes much to your project, but what has the 'nrf24l01' to do with WiFi?
    Unfortunately, that does not make it WiFi. Bluetooth also operates on 2.4GHz.
    Wireless yes. WiFi no.
    yes nrf24l01 use same frequency but not support 802.11 standard then not properly wifi standard
    is only generic indication but this module can create your own network with tcp protocol
    https://github.com/TMRh20/RF24Network
    You really need to change your description.
    It is not at all WiFi, it is NRF24.
    When you look at the poster above he is also confused and your reply is even more confusing (you mention a WiFi module where it is a NRF24 module).
    As mentioned, I like the project but the description is just wrong...
    hi, that is an interesting project but i can't seem to see which part is wifi related?
    think you need to show more steps so that it's more understandable. good in theory but lack of procedure.
    i make this projects in my free time and English not is my native language
    if you or other people make this project you can develop complete detailed guide with the link of the inventor
