Have you ever knocked over your recycle bin? Have you ever wanted to use only one cleaning tool instead of two? The solutions is to make and use the Carbage Collector 200. It is a simple garbage collector that collects garbage with just a simple push!
Materials:
    - Plastic Container
    - Metal Rod (Cut into Two Rods; Need to be hollow, hollow metal garden stakes also work)
    - 1 Paint Roller
    - Metal Clothes Hanger (Unscrew it into a metal wire)
    - 2 CD's
    - 1 Coupling
    - 6 Foam Paintbrushes (using only brushes)
    - Receipt Paper Roll
    - Rubber Belt
    -2 Tub and Shower wheels
    -1 Fastener
    -flat aluminum sheet
Tools:
    - Wire Cutter
    - Tape
    - Retractable Knife
    - Krazy Glue
    - Scissor
    - Saw
Step 1: Checking Measurements-Cutting Out Placements
Depending how big you want your Carbage Collector 2000 to be, you will need to measure your materials relevantly.
First, we will need to create holes and slits into the plastic container.
For the wheels, make a cut in each of the rear two corners, large enough to put a CD inside. Then puncture four additional holes on the sides of the container for the rods to hold onto the sweeper and the wheels together, they will be used to as holes for the axis's to hold the wheels and sweeper in place. on the bottom cut about two inches of the bottom container from the front of the container.
There is a hinge door located on the bottom of the container. You take a piece of flat aluminum and cut it out to fit the container. This will ensure a better entry into the container when swept
landongaga says: Oct 19, 2012. 7:19 AM
that is very nice but as if it picked up dust
natiboy says: Jun 12, 2012. 11:27 PM
nice i see it worked
DoctorDv says: Jun 12, 2012. 12:15 PM
Cool! Please post a video!
-Doctordv
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
