Introduction: Carbine Hook and Key Fob
Picture of Carbine Hook and Key Fob
Ideal for camping, Great for scouts to carry penknife and other bits and pieces, e.g. compass, whistle etc when trekking a really quick and indestructable craft all you need is
10 - 15 minutes to make it
Duct Tape
String
Carbine hook
Split Ring
Step 1: Step 1 the Strap
Picture of Step 1 the Strap
Lay out a piece of duct tape about 15-20cm long on the table sticky side up
Now cut two pieces of string longer than the tape
Stick the string onto the tape equally so that the string is divided over the tape in thirds
see the pictures
Step 2: Step 2 Secure the Strap
Picture of Step 2 Secure the Strap
Now fold over the tape so that the string runs along the two sides
make sure you press the tape firmly down and avoid creasing the duct tape whilst you do this
Step 3: Step 3 Securing the Strap
Picture of Step 3 Securing the Strap
I used two pieces of 1" duct tape for this but you can use the normal size if you like
lay two pieces sticky side up about 5-10 apart it depends how long you want the strap
Now place the strap on the top
Step 4: Step 4 Adding the Split Ring and Carbine
Picture of Step 4 Adding the Split Ring and Carbine
Feed the split ring and Carbine onto the edges near to where the tape goes downwards
fold over the tape to secure the split ring and fold the 1" tape around the main body to secure the ring in place
Repeat the same thing with the Carbine
Check the are securely fastened and stuck down
Now trim the string with scissors and smooth out and creases or bumps
Step 5: Step 5 Add the Outside of the Tape
Picture of Step 5 Add the Outside of the Tape
Carefully cut a piece of tape to the right length of the body of the strap
Now place this over the outside of the tape and get it as central as you can
Smooth out any creases
Turn the whole thing over and fold in the two side carefully to avoid creases
Step 6: Stand Back and Admire Your Work!
Picture of Stand Back and Admire Your Work!
smooth out any creases, stand back and admire you work
Quick and easy, idestructable and waterproof
Cheap to make and handy to have whilst camping and trekking
3366carlos (author)2013-03-22
great idea.
Cheers Carlo$
About This Instructable
1,040views
11favorites
License:
More by The Craft Club:Carbine hook and key fobPing Pong CatapultAwesome crossbow and carrybag
Add instructable to:
