Carboard Ukulele Stand by eplunkett
Step 6: Measure slot...
On the template, there is a line marked "Cut Centerline".  Transfer this line to each of your pieces.  This is the centerline of the slot that you will cut.  After drawing the line, measure half the thickness that you determined in the previous step on either side of the line, so that you will wind up with a slot the same thickness as you stack of cardboard.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
