Step 4A Word about Alcohol
The Anaerobic process is also known as fermentation. During strenuous usage of muscles, your tissues generate energy (quickly) using anaerobically - the by product being that ever so nasty Lactic acid. Our yeast won't be running any marathons, but it will be generating energy anaerobically. Instead of lactic acid, it will be making ethanol.
Not to worry though, ethanol production will be less than .5% by volume - that is, less than 1 proof. A healthy human body can process ethanol at a rate of about 1oz. per hour. This 2l bottle contains 1/3 of an ounce of ethanol (if we assume the maximum case scenario for alcohol production). So, if you were to drink the whole 2l bottle in a few minutes and IF we assume you absorbed all .3oz of alcohol, the alcohol would be out of your system in about 20 minutes after absorption (which can take 20 minutes).
So for a 12oz. ale (typically 6% alcohol by volume) - you need to drink almost 1.5 gallons of this home made drink rather quickly. For that matter, you probably should not be drinking that much - someone recently died from such stupid acts.
Now, if drinking alcohol is against your devout beliefs (Islam, Orthodox Judaism, Buddhism etc.) - you may want to avoid making this drink. However, I will have an "instant root beer" recipe soon. It just requires some fine tuning.
Similarly, if you are extremely sensitive to alcohol. You probably should avoid.
Of course, I am overstating any risk here ;)
Contrary to a comment -- this is not a Rum. There are many ratings/standards (typically age and/or proof) for what makes rum -- this varies country to country. By the most lax definition, this comes nowhere near rum. Hell, it's not even distilled. Not to mention, when was the last time you had a carbonated rum?
This almost (by technicality) is not a beer. But because there is a fermentation process (which happens while it is carbonating), it meets criteria. I guess you could call it a water beer (as was consumed ages ago due to low quality water). The "instant root beer" recipe, by technicality, is not a "beer" -- just flavored ;)
4
comments
Add Comment
noahh
says:
Add Comment
