3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Card set to hide things in
When I was about to throw away my cards (lost a few cards, and it needed replacement anyway), I thought of making this: a pack of cards with a hole in it to hide things in. It can be anything (as long as it's small). How about some spare money? Maybe a few batteries, or a mini knife. I use it to keep some spare money with me.
I used pieces of leather from an old wallet to line the inside with. It looks very neat, if I say so myself.
Note: don't underestimate the amount of time this will take. Took me about 2 hours. You have to cut and glue every single piece separately.
Second note: remember to be careful with knives!
Step 1Materials you need.
Materials you need.
-A pack of cards, obviously
-A ruler
-A sharp knife. I recomend an xacto knife, but I used a small spyderco knife because that one is actually sharper than a xacto :)
-Scissors
-A few pieces of leather, or felt. You can probably use a lot of different materials for this. Or you can skip lining it at all, since that saves some work.
-A cutting board might be a good idea, since you will be cutting with a sharp knife. Don't want scratches on your table, even if it is a workbench!
What I forgot to include in this photo is glue. Very important :D
Any kind of glue is okay, I guess.
53 comments
1-40 of 53next »
Apr 15, 2010. 3:37 PMroundthingsroll says:
Hi. I made one, and I love it. I used orange felt for the liner, and put in two rare-earth magnets, one at each end of the body, then broke an exacto blade and sandwiched those metal bits into the lid, now the magnets keep the lid closed.
Thanks for the excellent Instructable and idea.
Aug 10, 2011. 3:56 AMshadow wave rider says:
great idea with the magnets. but the holes for the magnet where made by a hole punch werent they. or did you drill it. tell me
Nov 25, 2010. 6:28 PMguyzo35 says:
I cut out a sheet metal stencil to trace the cut onto each card, to ensure all the holes were the same size. Fits a buck knife, LED flashlight, and some matches (I glued a strike pad to the inside). Thanks for the idea!
Jun 8, 2010. 6:22 PMbadblb says:
i had two cards i cut the center out of one of them then stapled a card on top on only the small top side with two staples so you can fold it up
Apr 4, 2010. 6:54 PMd.i.y master says:
here are those pics you asked for
Apr 1, 2010. 5:35 PMd.i.y master says:
Wow its creepy but when I made one it took me exactly 2 hours like you said!.
Mar 27, 2010. 10:05 AMralphab says:
 To speed up the gluing process, try  power gun nailing the four corners of the deck together then gluing top and bottom to cover the nails. Also to cut multiple card layers drill a pilot hole and use a jigsaw to trim the inside (after power nailing). I've successfully jigsawed layers of paper before. Maybe a rubber band in two directions would hold everything together (like we did in college for a ready game.)
Mar 26, 2010. 8:25 AMRick.Cartwright6 says:
Nice Spyderco!
Mar 25, 2010. 6:52 PMvanillabean says:
For attaching the bottom cards:
How about a pin/pivot mechanism. I know you said that but hear me out:
- Cut a hole for the pin to sit comfortably in the deck with enough space on top to allow the cover to rotate.
- Super glue the hole. Stick in the pin (through the cards of course).
The pin would be secure, though the cards may still be fragile, depending on how you treat them.
For even more security: Add a magnet in between the two cover cards opposite the pin. Then add a magnet (more cutting!) so the top is one card down from the top of the box. Voila?
Mar 25, 2010. 5:26 PMMcCoolman says:
 try magnets
Mar 25, 2010. 2:48 PMSmokeDestructer says:
Well, you could try using half or 2/3 of the deck to make a bottom part, put around a small box without a top, then glue the rest of the deck together with the top couple of cars not cut, making a lid that would go around the interior box. I'm not sure if I did a good job explaining that, but there's my suggestion.
Mar 16, 2010. 1:46 PMHuman Being says:
awesome!! for the title, how about something like, "How to Hide Something in a Deck of cards"
Mar 25, 2010. 2:39 PMSNiPERSeyes says:
thats the greatest name i have ever seen, human being, oh god if i have children im gonna name my son human being....
Mar 16, 2010. 3:08 PMJohenix says:
Better idea: Casinos here in the states give away drilled decks of cards. (Drilled so you can't use them to cheat the casino.) Seeing you can drill a deck:
1.) Take your 35 cards (52-17) and drill a hole in the center of the deck.
2.)Glue the cards front to back.
3.)Put a bolt through the hole to compress the deck and let the glue dry.
4.)Now with the bolt and glue holding the deck solid, drill four corner holes and then with a coping saw cut out the center of the deck.
Mar 18, 2010. 12:03 AMXOIIO says:
I'm going to try gluing the whole pack together then using my rotary tool, I'll let you know how it workd out. What kind of glue should I use for a really strong bond?
Mar 25, 2010. 6:20 AMDannyBoy97 says:
I made a hollowed-out book a while back, and glued the pages together first.  I used a 50/50 mix of Elmers glue and water, and just brushed it liberally along the edges with a small paintbrush.  It dries clear, and since it's watered down, it seeps in between the edges and holds together very well.
Playing cards are heavier, glossier stock, so I'm not sure if the same solution would work, but it may be worth a shot!
Mar 18, 2010. 6:09 AMFieldownage says:
 Blast! You stole my comment!
     Yeah I'd glue them all together first and then do the rest OR glue everything else than couple of cards so you'd just need to make a hole and then glue bottom. And for the glue, PVA is the right choise (wood, paper, etc.), I guess because if you use something that'll push the cards together while the glue is drying... Well if it fails after that, the cards have failed.
Mar 20, 2010. 8:46 AMZonariAn says:
Nice project!
I have an idea for a lid.  I just came up with it while flipping open and closed the case that my zune is in, which closes magnetically.
Get 8 small disk-shaped magnets.
Use a hole punch in each corner of a stack of cards just thick enough to encase the magnets flush with the stack (so that it's still thin).  Seal the magnets inside the holes in the stack with a single card on the top and bottom.  This will be the lid.
Take a segment near the top of the stack that is the container (the cards with the center cut out)  and repeat with the magnets, sealing them with a single card on the top layer.
Doing this would make the internal space a little shallower because you'd have to dedicate more cards to the lid, but all in all if you took the time for detail, you would have what seemingly appeared to be a normal deck of cards, with no visible magnets or gaps.
I hope I wrote it so that it's easy to understand the way I saw it...If anyone wants me to make a little illustration to help then I will.  :D
Mar 22, 2010. 11:44 AMtrebory6 says:
 I was thinking about something like this too! Wonderful Idea!
Mar 20, 2010. 1:21 PMlinq008341 says:
I'm planning to be a girlfriend, thank you for your good ideas(S—ÙsËZ* ""`„})
Mar 19, 2010. 7:16 AMcowscankill says:
I should try this. My brother is throwing away three decks of cards.
Mar 18, 2010. 9:42 PMshaneomacmcgee says:
What if you didn't fold the leather over to the top of the deck, and just glued it to the sides? You wouldn't need to cut the middles out of these cards, so you could use them for something else. I was thinking a lid. If you cut the cards the same as the first step, but glued the middles together, then glued that to the three last cards, so it wouldn't slide off.
If that makes any sense.
Mar 19, 2010. 4:21 AMMinja13 says:
You might be able to put the lid on with a brad fastener. It would have to be a long one, but it might work...
Mar 18, 2010. 11:58 AMplace name here- says:
This is sweet. you could use magnets in the deck & small bits of metal in the lid so it would self it wouldn't need to be thick.
Mar 17, 2010. 1:45 PMmerleman says:
deck of stash sounds cool or stash cards
Mar 16, 2010. 11:16 PMlittle_noob says:
 nice thinking. This should also be good for some kind of magic trick too...
Mar 17, 2010. 1:37 PMBobicusIX says:
(if you don't have magnets, that is)
Mar 17, 2010. 1:36 PMBobicusIX says:
taking money out of deck of cards, maybe?
That would be pretty awesome, although you would need to have a bottom on the deck.... DOUBLE STICK TAPE!!!!! that would be a great way to keep the cards on the bottom on!
Mar 16, 2010. 11:42 PMNatureBoom21 says:
:O where did ya get that knife! i want one!
Mar 17, 2010. 6:40 AMbustedit says:
@Nature - I think that is a Kershaw brand knife. they make great lil knives.
Mar 17, 2010. 11:09 AMNatureBoom21 says:
 THANNNKKK YOOOOOOUUU
Mar 25, 2010. 11:57 AMfidgetingfinch says:
 You could probably fit a Kershaw LFK in there too. It's an awesome knife for the price. I seriously have $100 knives that aren't as sharp as that $30 Kershaw.
Mar 17, 2010. 9:03 AMnolte919 says:
I like the title.  It's precisely describes what it is, which is what a title should do.  And you might have a hard time changing it, ibles are listed by their title.  You might have to make a new ible with the new title and transfer over the content.  And that would mean you'd lose your featured status.
1-40 of 53next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:eygen
