Introduction: Cardboard Armor, Full Set 1
Picture of Cardboard Armor, Full Set 1
This Instructable is in reply to a challenge sent to me by Danger_Dolan
The challenge: ...thanks! i also have a challenge for you! my challenge is: make full body armor. legs, feet, arms, breastplate, and face piece! all out of cardboard! i would like to see if you can do that. thanks!
Step 1: Intro
This instructable is split into five parts.
Head-Helm
Chest-Breastplate+Pauldrons
Arms-Gauntlets+Couters
Waist-Tassets+Belt
Legs-Greaves+Poleyns
Step 2: Part 1, Head
Materials,
Cardboard
Old plastic helmet
Brass fasteners
Tape
Step 3: Disassembling Your Helm.
Picture of Disassembling Your Helm.
My helm started out as a horned helm with gold trim. After taking off the horns and rim, I was left with two holes on either side of the helm which I covered with cardboard circles and tape.
I was also left with four small holes around the rim of the helm, which I used to attach the rest.
Step 4: Bigger Helm
Picture of Bigger Helm
The helm really depends on what size head you have and what you have to use, so I ended up taping three pieces of cardboard together and using brass fasteners to attach them via the holes left from disassembly.
Step 5: Faceplate.
Picture of Faceplate.
Because I like to hide my face, I Made a simple faceplate by cutting eyeholes, and a small triangle out of the top of the mask. I folded the cardboard inwards until the two resulting flaps met, and tape it into place.
Step 6: Finish
Picture of Finish
I attached the entire thing to the helm, taped it for color, and came out with a pretty nice helm.
Step 7: Part 2.
Materials,
Cardboard (A lot of it)
String
Tape
Step 8: Breastplate
Picture of Breastplate
Using a single large piece of cardboard.
Create a ridge by folding the piece in half, then back up as shown.
Trim into desired shape, keeping functionality in mind. You will need to be able to move your arms.
Step 9: Backplate
Picture of Backplate
Cut a piece of cardboard around the same size as the breastplate.
Step 10: Attaching the Two
Picture of Attaching the Two
Poke a hole in each corner of each piece.
Run a long string through each hole of the bottoms of the pieces.
At the top corners, tie a string as shoulder straps from the backplate to the front plate.
Step 11: The Pauldrons
Picture of The Pauldrons
Take a sizable piece of cardboard.
I ridged the center like the breastplate. This is optional.
Cut two slits almost to the center as shown. If you cut all the way through, it's not that big a problem, you can just tape the center back together.
Cut a triangle out of the cut as shown, and fold the piece inward until the resulting flaps meet, then tape them in place.
Shape the pauldron as you wish.
Step 12: Attaching the Pauldrons
Picture of Attaching the Pauldrons
At the points you attached the shoulder straps, poke a hole next to it. also poke holes in both top corners of both pauldrons, using small pieces of string to attach them as shown.
Step 13: Fixes
Picture of Fixes
First on the backplate, cut a small slit in the top center, and fold inward so the pieces overlap. Tape into place. This helps give shape and make it look less barreled.
Next is on the pauldrons. On the back of each pauldron, poke a hole, and run a string between the two so they stay upright.
Step 14: Finish
Picture of Finish
Tape for color if desired.
Step 15: Part 3.
Materials,
Cardboard
Tape
String
Step 16: Starting the Bracer
Picture of Starting the Bracer
Get a piece of cardboard about the length of your forearm.
You may ridge the center if you wish.
Trim the elbow end into a point, and trim down the long sides as shown. This is for function.
Step 17: Couter. (Elbow Armor)
Picture of Couter. (Elbow Armor)
This piece is basically made the same was as the Pauldron.
Cut to the center
fold,
cut the triangles out,
tape.
BTW, cool Helmet idea on pic 3.
For a styled fan plate, Cut one end of the piece into odd shapes.
Step 18: Attaching the Two.
Picture of Attaching the Two.
Align the two pieces, and poke two holes through both pieces as shown.
Use string to attach the two as shown.
Step 19: Stringing.
Picture of Stringing.
As shown.
Step 20: Finish
Picture of Finish
Color as desired.
Step 21: Part 4.
Materials,
Cardboard
string
(1 pop tab/soup can tab, a shoelace/hoodie string,1 brass fastener) Or a belt.
Step 22: Swing Them Hips!
Picture of Swing Them Hips!
Get a piece of cardboard that will cover one hip nicely.
Cut it into a shape you like.
say, "Wow that was an easy step."
Step 23: The Belt.
Picture of The Belt.
If you don't have a spare belt, do this.
Put the end of the lace through the hole and brass fasten the together as shown.
Step 24: Attaching the Tassets
Picture of Attaching the Tassets
Poke two holes in the corners of the top of each tasset.
Run a piece of string through the hole, and tie the end onto the belt.
Step 25: How to Tie the Belt.
Picture of How to Tie the Belt.
For this style belt, it is very easy to tie.
Run the end through the hole, and tie the string in a knot around itself.
Step 26: Finish
Picture of Finish
Color as desired.
Step 27: Part 5.
Materials
Cardboard
Tape
String
Step 28: Wow.
This part is basically the exact same as the gauntlet, except slightly bigger.
Step 29: "Innocent Whistling"
Picture of "Innocent Whistling"
Ridge,
Cut poleyn (Knee couter) to center,
Fold,
tape,
poke holes,
Attach with string.
Step 30: Next
Picture of Next
There are, though, some differences.
First, cut a short slit blow the knee as show.
Second, you will need to cut a triangle from the bottom of the greave for your foot.
Cut the poleyn into a desirable shape.
Poke four holes, one in each side, and string as shown.
Step 31: Finish
Picture of Finish
Color as desired.
Step 32: I Found This Funny.
Picture of I Found This Funny.
Step 33: ABSOLUTELY FINISHED!
Picture of ABSOLUTELY FINISHED!
WOOOOOO!
Yeah!
This took a few days, but it was worth it!
Thank you Danger_Dolan for the request!
Sincerely yours,
Nemesis.
Danger_Dolan (author)2017-12-14
this was challenge i sent him! it is really cool nemisis.
I'm glad you like it!
is it okay if i mention you in my account descripiton? saying something like, if you want to see more cardboard stuff, see my friend Nemisis-Perilous?
Sure, if you'd like.
hey i posted an instructable! see what you think. it is called:
NERF GUN STORAGE PROBLEM
i am a nerf nerd if you did not already know.
yeag
It was a great challenge and I had a lot of fun!
LordofHosts (author)2017-12-13
How comfortable is this? And do you need help putting it on?
And speaking of the Christian God, I was thinking about making a Templar set.
It is surprisingly comfortable. everything adjusts purrfectly, although I recommend wearing a long sleeved shirt with the gauntlets, and I can put it on in less than ten minutes.
About This Instructable
79views
1favorite
Bio: I am a cardboard blacksmith, hard at work making armor and accessories. Skyrim, Sword Art Online, and Lord of the Rings all the way. If ... More »
More by Nemesis-Perilous:Durable Prop Axe.K'NEX Micro, Articulated Man.Armoring Your MLP
Add instructable to:
