Step 1: Breastplate and Backplate
For the front and back plates (together these are called a cuirass), I first drew a flat shaped based on my body measurements. For the front I used these:
- front of the waist (a little more than half my waist measurement)
- length from waist to shoulder across bust
- length from waist to bottom of neck hole
- front of the bust (quite a bit more than half my bust measurement)
- width from arm to arm, above the bust
- length from waistline to underarm hole
- back of the waist
- width from underarm to underarm
- width from arm to arm across the shoulder blades
Cut out the pieces with a knife of some kind - a utility knife or box cutter works well. Cut only the lower side of the dart marking all the way through. The upper side, cut through only the top layer of cardboard. Then peel the top layer and the corrugations off, revealing the inside of the corrugated sheet. It looks like a small flap. To construct the darts, bend the cardboard so the dart edges meet, and hot glue the flap down to the outside of the front plate.
It's easier to bend the cardboard if you score the inside first, just run the cap of a pen firmly along the line you want to bend on. A stiff ruler helps a lot for scores that run diagonally to the corrugations. In addition to the bust area, score and bend the shoulders and sides.
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
