Yea..you know, like that stupid $10 "Cat Scratcher"...yea...you know the one, the block of cut down and glued cardboard strips?
Every time I'd buy one, I'd shake my head. Might as well give my cats $10 to play with and eat.
This is a great solution for you. As it's been for me.
Remove these ads by
Signing UpStep 1What you'll need.
1. A cat (in my case Three).
2. A piece of Card Board - 32x24 (I used 3 due to the amount of cats).
3. A razor for cutting.
4. A 36 Inch ruler (I like the metal ones).
5. Some glue.
6. Optional Cat Marijuana.
Took your basic premise but put the strips into the bottom of a 12-pack soda box. Fingers crossed she learns to scratch there and not my boyfriends golf bag LOL
1. large cardboard box.
2. folded it to a size I thought the cat would like.
3. wrapped it around with twine.
5 minutes or less.
Cat loves it.
I'd like to know how to grow cat nip.
Then get another scrap of 1x2, screw/glue/nail/whatever it to the other perpendicularly (making a T shape), with the scrap under the blade board. The length of the blade board should be picked before fastening, just measure from the scrap board to the blade to set the cardboard strip width.
To use, place the cardboard over the edge of a table, put the cutter on the overhanging edge, with the scrap board parallel to and against the cardboard edge, and slide the cutter. Lather, rinse, repeat, feeding the cardboard off the end of the table for each cut, so the blade is always at least a couple inches from the table edge.
There are many, many ways to make a cutter or jig. For example, another way is to use the above T cutter, but with a standard utility blade. Now add another 1x2 piece under the scrap T edge, parallel with the blade piece. When setting the blade, run it down until the tip embeds in the lower 1x2.
Or yet another quick version - build the T cutter, but fasten it to a decent sized piece of scrap plywood. Rather than running the cutter over the cardboard, set the cutter on the floor, and run the box through it.
If you have scrap wood and fasteners laying around, your only costs will be the occasional replacement carpet or utility blade.
I could probably whip up a couple of examples if the above don't make sense. I'll just have to see if I have any scrap 1xXs or not.
I make a similar scratcher for my cat, but without glue. I'm just about to do an Instructable for it, figured I'd search first and see what else was out there. Free cardboard is so, so handy! I've actually wondered if the companies making the $10 scratchers are *also* getting it free. I bet they are!
I like your step about how a cat is required. :)
