3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cardboard Catch-all Shelf (2nd Edition)
Though it's served its purpose, the Cardboard Catch-all Shelf I made to toss my stuff on just wasn't all that pretty. This one, however, not only holds a phone and keys, but also looks pretty nice!
Step 1You'll Need. . .
You\
  • - the template here (can be modified in Photoshop/G.I.M.P./similar programs to add designs or patters - the shelf can also be made without the paper if you like the look of plain cardboard) - note that you should cut so that the gray portions are left behind; the thick black lines are the tab cuts and the thin black lines are folds
  • - some cardboard (enough for an 8" diameter round and a 9"x4" strip)
  • - scissors
  • - glue (if you want to stick the paper on, if not, you don't need it)
  • - some push pins
support.pdf(576x287) 244 KB
top.pdf(576x576) 495 KB
20 comments
Jan 14, 2010. 11:09 AMlegendofmatt says:
I was thinking you might try adding a Lip to the top so as to catch change. or other small items
Oct 12, 2009. 2:01 PMsarah_ashley4113 says:
 this is just awesome. great idea and way to use those extra boxes laying around once you move in.
Aug 5, 2009. 1:45 PMIAE says:
this must catch everything huh?
Aug 5, 2009. 6:55 AMamakerguy says:
This is very cool and green also!! I love it!!
Jul 27, 2009. 8:16 AMDELETED_DELETED_HIVLTGE1 says:
(removed by author or community request)
Jul 30, 2009. 5:06 PM15zhangfra says:
hey you could try using Velcro or something to give it a nicer appearance rather then push pins, and you could water proof it and use it to hold soap at an easy-to-grab height
Jul 27, 2009. 6:55 AMsolo.card says:
Good idea! A pretty easy concept to modify too... I like you key-ring too,
Jul 26, 2009. 4:50 PMoldanvilyoungsmith says:
if you coat the cardboard with a thin layer of polyurethane it should protect it from moisture, and make it look pretty
Jul 25, 2009. 8:15 PMsk8erdude says:
rumour 2? nice. i have one in orange!
Jul 25, 2009. 8:09 AMSl0whand says:
Will do! I like the pattern! Is it an Irish-keltic knot?
Jul 25, 2009. 7:03 AMSl0whand says:
That is a great idea!
And refering to bruc33efs comment:
Is it possible to paint it with some white paper glue diluted in some water, to give it a water resistant finishing touch after it dries?
Thank you for your posting!
I'm going to put it in practice!
Jul 25, 2009. 12:22 AMbruc33ef says:
I think it's a really good idea -- both of them. Cardboard is an under-used and under-appreciated resource. The only things that would degrade these shelves are weight and moisture but with a little caution they should work fine. Nice job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
283
Author:shesparticular(Sometimes I tweet about stuff)
Learn more about me here: http://www.instructables.com/id/Featured-Author-shesparticular/ or follow me on Twitter (@shesparticular) (if you're into that sort of thing).
