Step 4Cut remaining frame sheets
Also note that two of your frame sheets should have a nice side. Two of the frame sheets will face outward and the remaining 4 will be internal frame sheets. We picked ones without tears from tape or markings for the two outer frame sheets. Also, try to make these two sheets have flaps along the bottom. These flaps may be used to attach the bottom sheet. Having bottom flaps on other frame sheets is also helpful.
If you have a limited number of large sheets then you can cheat on the internal frame sheets since they do not have to be as pretty. Combine medium sized sheets together to form a larger sheet. For example, you can tape two sheets together, or you can use one sheet for the back radial beams and another for the front radial beams. What you want to achieve with the frame sheets is to form a connection between the beams. The frame sheets themselves do not provide direct seating support so if you have to use some of the above cheats it will be ok.
Add Comment
