loading
Step 2: Slicing the lamp in 123D Make
I used a preview build of 123D Make to deconstruct the 3D model into a series of radial slices.
In case you haven't heard me rave about it before, 123D Make is a free app that does one thing and it does it extremely well. It takes any 3D model you give it and quickly lets you convert it into 2D vectors that can be cut from sheet material. At the moment, the publicly available version only allows you to perform simple slicing and to create perpendicular interlocking waffles, but future releases will allow for radial slicing, surface paneling, complex joint-making and a large handful of other cool things. With a bit of luck, these updates will appear online within the next couple of months. Watch this space!
Once I'd adjusted the radial center of my grid to align with the center of the lampshade, I fiddled with the number of slices and the material thickness until I had something that could support its own weight when made from cardboard.
<p>i need the pdf files complete somebody can send me the files? please</p>
You can convert the files online.
<p>Very cool design. However, the cost is a wee bit on the high side. Would it be better to just get a LED desk lamp. The Lumiy Lightline 1250 LED desk lamp is less than $50.</p>
<p>What kind of cardboard did you use? I assume regular cardboard boxes from the local store will not do.</p>
looks good !! made with 3 mm MDF board
<p>Nice work!</p>
<p>muy arrecho</p>
<p>hello I wanted to run your own lamp 3d but unfortunately in the drawings is missing some pieces. Could you send me the complete design thanks</p>
<p>DXF file format please... ?</p>
<p>How thick is the cardboard you used?</p>
<p>Did one up the other day. came out looking great. Had to make a few changed during assembly because of the socket my home depot had availible had a different clamping setup and differnt profile. </p>
<p>And I would recommend using a spot LED instead of a stanard edison type bulb, too much light escapes the sides making this lamp hard to look at. </p>
<p>I downloaded your eps files and just wanted to verify one thing. The eps with the single part in it (part 0) is not on top of the &quot;canvas&quot; in the file. I'm assuming that makes no difference when attempting to print?</p>
Beautiful, but.....can you say fire hazard? I knew you could!
A fair point. As I mentioned in Step 6, this has only been tested with low-heat LED bulbs. I suspect that using it with a normal bulb would lead to... interesting lighting effects.
Indeed. Needless to point out, but there are a certain number of people who lack the ability to read directions....or warning labels, either, for that matter. I'm just doing my part to keep those folks from burning down their homes.
survival of the fittest?
if they lack the ability to read directions...they lack the ability to read your part!!!
c est magnifique merci
.eps file is not opening,can you plz upload file fresh in pdf or eps.so i can cut on laser cutter <br>
Dear friend <br> <br>Anybody can advise the setting for use laser cut the cardboard? <br>(I don't want to bern the machine) <br> <br>Thank in advance <br>Best regards <br>ThaiZyber
Depends on the power of the laser. Low power and fast speed should be fine. I use a 100 watt laser so it cuts 4mm MDF with ease on a fairly quick setting 350cm/min on circa 50% power. <br>Cheers <br>Tony
Saw this and though, AWESOME! Have acess to a SEI Mercury laser running ICARO software so thought I'd give it a go. The software opened the .eps file no problems. I deleted all the numbers (reckon I can figure the assembly out without them) and made sure all the layers and laser settings were okay. I cut the lot in one go out of 4mm mdf which the laser managed with ease. Not assembled it yet but tried a few pieces and the fit is great with the 4mm. Just need to find the right type of lamp fitting here in the UK now and I'm sorted. Many thanks for the files. <br>One minor point though, a DXF file would be great as it can be edited and re-nested at the desk as opposed to on the machine. Just a minor point.
wow ,really ,good designed ,i admire your intelegent!
Files seem to open only in newer versions of Illustrator (I am using CS3). Please add alternative, more universal formats. I think this interesting project will benefit from these additions.
This lamp is great! - I loved it! - I bought it!!<br><br>The store doesn't have a place for reviews, so I'll review it here: There were no instructions included: What you see here is what you get. That was enough to 'get er done', but maybe some insider insight would have produced a better build. As it was, the laser burned part numbers/markings were cryptic and a fair number of joints had to be forced. All well and good when I'm making stuff out of old boxes, less cool when I paid for a laser cut kit. Sorry to rant, but not sorry enough to quit... The packing method used (Cling wrap a pile of cardboard pieces to one big pice, throw a heavy lamp unit on top) ensured numerous parts were bent. Lastly, QA was asleep: I received two #7 discs, and no #8 disc.<br><br>So maybe a store is not a good idea.<br><br>Happy Valentines!!
Hi, <br><br>I have been trying to get help with 123D-Make. Everytime I try to import a file, the software just crashes. I tried different OBJ files. Have you run into that trouble? Any idea what I am doing wrong?
O.О That was just great!
Sold out! Oh man! Would you make one more for me?? Don't have a laser cutter, great office conversation piece. Let me know.
this is a fine project, i've had problems with the .net 4 framework requirement, really slowed down my poor old surplus computer, also autodesk123 left out <br>some of the best line tools from older autocad.
Awesome! I am also wondering that would collect so much dust? or NOT? Thanks for sharing!
EPS not opening, cAN U PLEASE UPLOAD dxf INSTEAD
Yes please I vote for DXF's as well my cutter doesn't understand EPS's .....OR does anyone know of software that can open EPS's and save as DXF's ......I can't find one!
Pls hepls include the EPS file with all of the cut-out pieces!
I've just added it to Step 2. I can't wait to see your finished version!
Super design, please send as EPS!
Posted!
Definitely post your design files on thingiverse.com so other people can make this same lamp! Sharing is caring.
Sorry about the delay! The EPS files are now up available here in Step 2.
Would be glad if if could upload the EPS or DXF file...Thanx in Advance
wow grest! very nise desing...
Is there any reason this could not be made out of laser cut plywood by a service like Pokono?
This would be even cooler in Coroplast! You could even mix different colors.<br><br>www.coroplast.com
I thought the same thing, but I have never heard of anyone cutting coroplast with a laser cutter. First of all you would need to use a dark color to allow it to absorb enough heat to burn/melt, and then you have the problem of it just flowing back together after the cutter has moved on.<br><br>I think a CNC router or maybe a CNC controlled knife would work better.
Ooh, not bad. There's also a bunch of the stuff around every time there's an election.
Is there any way you could email me the demisions? i dont have a laser cutter or that software so i have to cut if by hand
D'oh! I forgot to include the EPS file with all of the cut-out pieces! I'll have these posted within the next couple of hours, so check back soon!
Hey. I really loved your lamp. I was just wondering if you can put the file for download. Because i would like to give this as a gift to my best friend. <br>Thanks in advance :)
This lamp is very cool, it uses recyclable materials, good looking (in a FEA way), lightweight. Wow, too bad i stay in south east asia, else i would rush down to the store and get one! <br> <br>You have done a most marvelous job, PenfoldPlant!. In this present world where things are made to throw away, you have shown how to repurpose everyday renewable materials. <br> <br>I have Solidworks but i dun know how to slice this 3D model into 2D slices. Any Solidworks experts here kindly advise?
About This Instructable
93,467views
670favorites
License:
Bio: Artist in Residence at Pier 9, currently exploring a vast array of new tools with which to injure myself.
More by PenfoldPlant:Candy Hearts (made with real heart) Haggis Pops Explosive Cocktail Foam
Add instructable to:
