Cardboard Honeycomb Organizer Shelves
3,387
64
14
Posted in HomeOrganizing
Introduction: Cardboard Honeycomb Organizer Shelves
About: I make useful low budget projects. I focus on home improvement, DIY gear and recycling topics.
I made these cute little organizer shelves for my work space.
They cost me almost nothing as only materials I used was a recycled sheet of cardboard and one hot glue stick.
They might not seem very sturdy but mine actually held up against 1 kg of weight.
Cardboard Contest 2017
Runner Up in the
Step 1: Tools & Materials
You will need:
  • A box cutter or an X-acto knife
  • Set square
  • Hot glue gun
  • Scissors* (optional)
The only material I used is a sheet of cardboard
Step 2: Measurements
I made hexagons 9 cm per side and 10 cm deep.
I bent the cardboard along the grain to get the straight edge that I used for drawing lines.
Step 3: Cuts and Bends
I cut the rectangle out and made shallow cuts across, against the grain.
Then I bent the cardboard along the cuts making sure that cuts were facing outside. Otherwise the measurements would get messed up.
Step 4: The Backing
I made a template using a graph paper but you can also print out a simple hexagon.
Then I glued the paper template to the cardboard and cut it out using the set square to make sure that my cuts were straight.
Step 5: Assembly
I wrapped the rectangle around the hexagon back and started gluing.
I started with tacking the corners and then applied the glue all the way around and up the connecting side, making sure to smooth out the hot glue with a nozzle of the gun. Then i added more hot glue on the back.
I added extra hot glue on the outside of the connecting sides to reinforce the link.
Step 6: Trim
I trimmed the excess hot glue with scissors.
Step 7: Hanging
I ended up making 6 of these and when they were done I hung them up using just a single thumbtack per honeycomb.
They held up perfectly in the field test.
The heaviest thing i put on these shelves is my paint supply which is around 500 grams.
I hope you'll give this project a try.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    14 Comments
    Good concept for recycling :)
    Wow, and you made me feel sorry that I bought a shelve for my wall :D. Thanks for sharing! This looks great and I will try to follow your idea to make a cradboard shelve to cover 2 visible holes from old shelve. I was wondering what to use:D.
    Hahaha :D. I'm glad I inspired you. Thanks for the feedback
    I think recycling all the cardboard boxes that come thru our homes and businesses is a GREAT service to the planet. I appreciate the attractive and practical display shelves you created! Do continue to share your wonderful ideas with us! And, THANK YOU!
    Thank you for your feedback, it's very encouraging. :)
    JuniorE5, May I please receive your comment(s) in English? Thank you very much!
    oh wow! I have been recently doing cardboard drawers and organisers, and I find this a useful and easiest to do. I will give it a try, thank you!
    Thanks for your feedback. I appreciate it!
    Thank you ^_^ The main goal was to keep them cheap but they came out pretty decent looking as well :)
