3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a Cardboard Laptop Stand
In this instructable I will show you how to make a sturdy laptop stand out of cardboard.
Why pay over 30pounds/$60 for a flimsy plastic laptop stand, when you can make a stronger and more environmentally friendly stand for free ?!
When I thought of this idea I was skeptical and didn't think the cardboard would be able to support the heavy laptop, but after a bit of brainstorming and some strength tests i thought it was possible and decided to give it a go.
When I had finished making it I tentatively lowered my laptop onto the stand, half expecting it to crumble and my laptop slide off the desk. Fortunately the process was uneventful and my laptop was perfectly happy sitting on top of its swanky new stand.
Even though the initial test was a success i didn't want to publish an ible that would fall apart in a few days and drop peoples laptops, so i decided to go the distance and do an endurance test. Now its just under two weeks since the first test and everyday i have put the laptop on the stand in the morning and left it there all day and then taken it off in the evening.
Results:
Perfect, The stand is like new, nothing bent, frayed or crumpled, its been really good having the screen elevated, much more ergonomic than usual.
Step 1Get Cardboard
Get Cardboard
Pretty easy, everyone has some laying around.
If you dont have any:
  • Ask freinds
  • Ask in shops
  • Look behind shops
  • Ask at supermarkets
  • Ask Parents
  • Go to recycling center
  • Ask anywhere that sells things, they will have some
101 comments
1-40 of 101next »
Dec 4, 2011. 1:44 PMgirvster says:
Harman/kardon Sound Sticks.... ROCK ON!!!
Sep 10, 2010. 1:23 PMMadrias357 says:
I've probably got a laptop that could crumple this one, but it's very big and very old. Don't know if you've ever heard of or seen a Gateway m675 with a 17 inch screen. If you have and had the misfortune of carrying, you'll know it's almost 9 pounds of portable computing power. (Specifications say 8.8 pounds, but we all know it feels heavier)
Jul 15, 2011. 10:38 PMhintss says:
oh, and I have one that will definitely crumple it, though you probably don't need a stand for it: huge desktop.
Jul 11, 2011. 10:23 PMhintss says:
I have one that might crumple it: old HP from about 2001 or so, came with windows 2000, and is about 1.5 inches thick. it was a low end model...
Aug 18, 2011. 8:35 AMqwerty987 says:
i saw a brand new laptop at a store with a 20 inch screen and it weighed over 20 pounds i think it had 16 gigs of ram and 2 terabytes of storage.
Feb 8, 2010. 3:15 PMblackcorvo says:
I'm thinking of doing one of those and maybe adding two coolers on the back wall to remove the hot air from the laptop's base (i have one of those "cooler tables", but it seems to not work at all... so i have to use my ventilator to cool off this thing).
May 12, 2010. 4:02 PMChowmix12 says:
 make sure to have the fans blowing air out of the box and away from the laptop, and add vents *not too much* to have a nice airflow, and also have negative air pressure insider the box. what this does is the negative air pressure actually causes a drop in temperature, and the airflow blows air through the bottom surface of the laptop.
Jul 11, 2011. 10:24 PMhintss says:
no. all computers I've seen had the fan blowing from the bottom to the side or back. additionally, making a negative pressure in the box puts strain on the computer's fan.
Jul 12, 2011. 7:27 AMChowmix12 says:
Yes you are right... the strain however is negligible..
Jun 20, 2011. 5:38 PMAssistantToTheRegionalManager says:
Thanks :) my laptops overheat all the time to the point of shutting down. My mom has these cookie cooling racks that I resorted to using before I found this. Works great, the fans don't even run unless its updating. I'm going to try to build one that folds down, without glue, so that you can store it easier. Thanks again :)
Feb 19, 2011. 5:19 PMcopper tube says:
i made one for my 10 inch laptop.
i ad a mouse pad and a drawer.
Apr 6, 2011. 5:13 PMThe nerdling says:
awesome!!!!!!!!!!
Oct 23, 2010. 7:24 PMDr.Paj says:
I used the same basic design as you, except that I don't have any glue so I had to use a kind of joint to hold the two pieces of cardboard together. I guess an advantage to my design is that I can take it apart easily.
I plan on making the middle section, between the two cross pieces, a semicircular cut on each of them for airflow through the middle section. Right now I can only imagine how hot the center boxes will be once my computer starts doing some serious number crunching
Jul 13, 2010. 10:34 AMrikstroink says:
Old newspaper=free cutting mat :D
Feb 25, 2010. 11:32 AMadil8476 says:
this is great!!! even though i haven't tried it yet i think its going to be awesome thanks!!!  :-)
Feb 15, 2010. 8:29 AMChromatica says:
 I'm going to make one with the new Toshiba I got for my Birthday(Yay).
Dec 13, 2009. 3:04 PMdudejetfighter says:
just finished mine works good
Nov 7, 2009. 4:40 PMtjmortenson says:
 Nice instructable.  I use this so my lap doesn't get so warm with my laptop on it.
Oct 1, 2009. 10:51 PMwildgift says:
Great instructable!
Sep 13, 2009. 9:43 PMFreak_09 says:
It would be good to get some flat, round pins. You could stick them in the stand joints as if they were nails, while the glue is still hot.
Aug 13, 2009. 10:23 AMamakerguy says:
AWESOME!!! I'm so going to make this when I get some cardboard!
Sep 3, 2009. 4:01 PMamakerguy says:
voted!
Aug 14, 2009. 8:22 AMamakerguy says:
if I have enough because I started cutting it up making a laptop bag. :o)
Aug 20, 2009. 8:06 AMRivertree says:
Nice - only if I make it I'll add ventilation - might even put in a fan - my hubby's laptop runs pretty hot. Hmmmm..... usb powered fan? ;D
Sep 3, 2009. 2:04 PMRivertree says:
Well! I made my laptop stand, only I only used 3 supports. The cardboard came from a bicycle box, so it was really strong - 4 layers. For ventilation, I cut 2 holes lower down in the back - about 3.5 inch diameter circles. Heat rises, and there's a nice gap in the back/top of the stand, so it makes a real effective cooler! My hubby loves it and his laptop is cooler than ever! I'll probably make another one sometime.... Thanks!
Aug 21, 2009. 6:52 PMPCfreak says:
all you would have to do is cut up a Usb Cord Add a Cap. And few resistors and solder the red and black wires from the usb cord to the fans (one in front an one in back) heres an ible of a usb powered fan
http://www.instructables.com/id/Yet_Another_USB_Fan/
Aug 21, 2009. 12:41 PMJackOfSpades says:
This actually sounds plausible. Just cut a hole, find a USB-powering tutorial, connect the fan, place it in and you are done.
Aug 14, 2009. 6:24 AMwenpherd says:
nice
Sep 3, 2009. 1:06 PMwenpherd says:
sure
Sep 3, 2009. 12:47 PMHobbyistX says:
I was having trouble with my laptop overheating and having stability issues.. (computer room is not climate controlled) I ended up making a stand very similar to this one except it has a vented top cover and two biscuit-type fans in the back, and now the laptop runs cool. As an added bonus, the keyboard doubles as an air-hockey table. :D
Aug 14, 2009. 9:11 AMhishealer says:
I bet you could change the angle by changing the shape of the pieces. To fit your own poor wrists and laptop, but the design seems sound. Nice one!
Aug 14, 2009. 8:59 AMLmatho says:
Great Instructable. I'm definately going to try this out. One comment is that Step 2 calls for cutting 2 support pieces. In the step 3 picture there are 2 side supports, but step 4 there is only 1 support piece actually used from left to right. I will build mine so as to match the final assembly in step 4, however you may want to clarify this. Hope this makes sense. Cheers
1-40 of 101next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
354
Author:=SMART=
I make lots of different instructables, I make stuff i need or want, then show you ! ............................................See my profile for further awesomeness :) ..............................
more »
