3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cardboard PC case
Cardboard PC case
This idea came up when I wanted to make a pc form old parts for my sister.I only had an old simple pc case but I wanted something a bit different that doesn't look bad to put in your living room.So I came up with this one..nice, blue cardboard box..
Step 1PC parts.
PC parts.
Please excuse my lack of step by step fotos,but I did this before I find out about this site so I only have it finished.I gathehered the pc parts,motherboard,ram,pcu,psu hard drives etc.
The most important here is that I took the metal pc case and dremeled it to pieces.The base were the motherboard screws and the pci-agp cards go is used as is because I wanted it to be solid enough and the cardboard was not.Also this way I have a better chance with the pci cards placed correctly.As seen in the picture in the left corner,its the dvd rack with the hdd rack uderneath and the psu on the bottom left.All of the components are bolded together apart from the duck tape you see.
28 comments
Sep 5, 2009. 7:26 PMgamermod says:
this is cool i got the same idea imma use my dish network dvr box lol
Jul 3, 2008. 12:33 PMRitsuki says:
I did this as well, with a Pentium 1 233. I took the power supply circuit board out of it's case, and made a cardboard enclosure for it so the PSU fan could pull air over the CPU heatsink. It's been running as my ftp and webserver for more than a year now with just one fan.
Nov 18, 2007. 10:00 AMPunkguyta says:
Fire anyone?
Aug 29, 2007. 5:52 AMTangMu says:
This looks awesome, my only concern is cooling. Perhaps with more "speed holes" and some fans on the sides you'd have less of a fire hazard
Aug 29, 2007. 10:12 AMWard_Nox says:
the ignition point of paper is 451 degrees ferinhight if your computer gets that hot you got bigger problems than a fire like the molten plastic ozeeing down your desk
Aug 29, 2007. 1:56 PMjwater7 says:
I did something similar a few years ago. But I decided to buy a real case because I didn't want to take the chance of having a fire. A power supply failure or any kind of sparking or bad wiring, anything...could cause a pretty easy fire disaster if it were inside a bunch of paper. Safest IMO, to just use a metal/plastic chassis. But fun/unique idea.
Oct 9, 2007. 3:45 PMhondagofast says:
I saw the PSU of a computer burst into flames because of bad wiring and over taxing it.
Aug 29, 2007. 4:30 PMWard_Nox says:
according to yoshi the risk is no worse than a regular case
Apr 25, 2008. 11:32 AMXellers says:
But a regular case isn't made of paper and will not burst into flames is a large enough spark from a power supply malfunction.
Oct 9, 2007. 3:42 PMhondagofast says:
I built one too some time ago! The pic I have of mine it is out of date, it started overheating, so I added a 80mm fan to the top. It's a 366 Pentium II, it was a 233 Pentium II, with 256MB of RAM and it has a N-Vidia GeForce 2400. =P It's slow, but I don't use it. Did I mention the 5.6GB HD and that it runs Win98?
Sep 29, 2007. 1:54 PMDarkshot says:
i hope your not serious with this instructble...."wanted somthing that didnt liook bad in my house" what if someone hates cardboard and wants to throw it away? if you want i'll delete this comment just give me a message
Oct 1, 2007. 4:51 PMDarkshot says:
to tell you the truth i dont know what point i was making either i was just in a weird mood that day :P
Oct 2, 2007. 4:35 PMDarkshot says:
i never hated it :-)
Sep 14, 2007. 6:06 AMhuit says:
please can I have the keyboard's references ? :D
Sep 2, 2007. 10:41 PMToulouse says:
well, i think it's cute
Aug 30, 2007. 11:45 PMzougaman says:
i like it.......................
Aug 29, 2007. 12:40 PM!Andrew_Modder! says:
eyhh.. idk.
Aug 29, 2007. 10:10 AMWard_Nox says:
meh i like the way Yoshi(creator of the Yoshi box or Y-box) did it on the screen savers he sandwiched the cardboard so the corigation was visible and acted as venting
Aug 29, 2007. 3:45 AMwhatsisface says:
O_O
It's as is you were copying me!
My Mod (Last year)
Aug 29, 2007. 6:21 AMwhatsisface says:
I used a leftover piece of self-adhesive vinyl flooring to screw all of the components to. The box measures 1"1in * 4in * 8in.
It was a bit of a tight squeeze, and I added extra fans for cooling.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:mastelios
