I wanted to make a small play house for the kids, but I didn't want to spend money.  Aside from a $3 pack of hot glue sticks, everything I used here is stuff I already had.
I searched online for geodesic domes so I wouldn't have to do all the math myself.  I found a suitable one that people suggested homeless people use as emergency shelter, then scaled it down and added squares on the bottom.
For this project, I used:
cardboard
box cutter
pen or pencil
ruler
hot glue
white school glue
clear spray primer and top coat
white spray paint
metallic spray paint (in two colors I happened to have)
black and white acrylic paint
metal powder mixed with white glue (use metallic paint if you have it; i didn't)
chopstick, napkin, and tape (use a round brush if you have one)
small paintbrush
large crappy paintbrush
Step 1: Measure and cut triangles and squares
If there were no doors or windows in this dome, it would consist of:
30 AAB triangles
10 BBB triangles
10 B squares
In this case, A measured 10 7/16 inches and B measured 12 inches.
I drew 1 inch flaps outside the edges of the triangles and squares (skipping the corners, as shown) so I could attach things together on the inside of the dome.
I left out three of the BBB triangles to make two windows and the top of the door for this project, and one of the B squares.
I suggest holding a ruler tightly while you slice along the outline of your shapes with a box cutter.  Remember to cut outside the flaps, not inside them along the triangle or square.  It helps to cut one and use it as a guide to trace the others, then cut the rest along the pencil lines, rather than measuring every time.
dataphool says: Dec 29, 2012. 6:23 PM
I'm impressed. Very impressed. Yours is the clearest way to plan and make a 'geodesic' dome. It doesn't seem very hard.
Problem. I have been heaving every box; now I will have to save them. How will I ever make up my mind. (wink)
adeejay says: Oct 15, 2011. 8:32 AM
very nice idea and work....well done, now i feel inspired, thank you!!
javajunkie1976 says: Oct 8, 2011. 5:32 PM
Oooh, I could make one of these for the bunnies! I just won't have the amount of ink you put on, but I think they'd like it. Looks like plenty of room for at least 6 buns.
Ugifer says: Sep 23, 2011. 4:38 AM
DRAT! I'm just sorry we binned that load of IKEA boxes last week!
Great instructable - and your dedication to decorating this just-so is remarkable. Lovely work.
SgtJellyfish says: Sep 4, 2011. 4:46 PM
Very cool! I like the steam punk colouring! (if thats what its men't to be!)
CementTruck says: Aug 19, 2011. 9:53 PM
I saw a full sized version of this in Maker Faire Detroit 2011. It was about 10 or 12 feet tall and made out of plywood. Pretty spacious inside.
fretted says: Jul 24, 2011. 12:38 PM
http://www.byexample.com/library/calculators/geodesic_dome_calculator/
Geodesic dome calculations made easy all ya gotta do is the labor you can makem kiddy sized or full sized like a house or garage this calculator takes out the heavy brain work !.
Nelyan in reply to frettedJul 28, 2011. 7:37 AM
Maybe it's just me, but how should these numbers be read? In a 2V Dome it suggests I have "35 Struts 30.9 cm each" and "30 Struts 27.33 cm each". These are the for the structure, right? So is the first number the A-lenght and B-length the second? Ugh, I'm having a hard time scaling this down.
fretted in reply to NelyanAug 9, 2011. 11:46 PM
The FAQ page on this site is awsome these guys covered everything to make it easier to understand check it out
http://www.desertdomes.com/faq.html
Nelyan says: Aug 5, 2011. 2:08 PM
I finally made it, but cat-sized :)
It inspired me to do a homage-'ible, http://www.instructables.com/id/Cat-sized-Cardboard-Dome/ , I hope you like it.
coollionsing2 says: Aug 3, 2011. 9:43 AM
Wow! Is that even possible to make!?
Mauigerbil says: Aug 2, 2011. 2:52 PM
COOL!!!! Im followin u
whisperonthewind says: Aug 2, 2011. 2:50 PM
I'm impressed. Very well done, both craft-wise and as a mom. You have discovered what heaven really is like.
Nelyan says: Jul 24, 2011. 12:54 PM
After reading this 'ible, I felt a need to create a playdome myself, you're never too old for these kind of things! I wonder how many boxes do I need to make one for two adults to fit in. :D (Oh, where would I even put it?)
And our new cat happens to love cardboard boxes, I could make one for her too so she would spend more time out from under the sofa.
One idea would be to try and make this out of fabric-covered parts with velcro to attach it together (and make it easily collapsible), but would it hold its structure? Any ideas, anyone?
whisperonthewind in reply to NelyanAug 2, 2011. 2:28 PM
Mod Podge - several coats should do it. I think they have one that makes fabric really hard. I'm guessing on this, but I've seen plans to make fabric boxes, and they use stuff like this. Google 'fabric boxes'.
Rahikainen in reply to NelyanJul 24, 2011. 4:20 PM
Maybe if u could make triangle frames out thin plywood or fiber board or something light and cover the surfaces with cloth.
I think the main point of constructing a big structure is to make it light to prevent collapsing and attach the parts firmly to each other.
boredcrafter says: Jul 17, 2011. 9:31 PM
I don't have a hot glue gun. I wonder if duct tape on the outside and inside may work. Ideas?
AbstractDragon in reply to boredcrafterJul 25, 2011. 2:59 AM
It might. Or you could save your change for a month and spend $3 on a cheap glue gun + $2 on a package of sticks. Walmart has some tiny but quite functional guns for around $3. I know, because I just picked up one after not being able to find my old one.
boredcrafter in reply to AbstractDragonJul 25, 2011. 8:27 PM
I have none moneys, but i suppose i could go sofa diving. we shall see. this project is on my to do list. :)
johnny3h in reply to boredcrafterJul 21, 2011. 3:44 PM
Duct Tape should work fine. Just be sure to apply it very carefully to guarantee maximum contact [no wrinkles if possible].
You could probably get by with Duct Tape just on the outside, but for maximum strength and rigidity it would be better to use it on both the outside and inside of each joint.
SimonRawr says: Jul 25, 2011. 12:44 PM
I was wondering how tall this turned out to be with your dimensions.
Rahikainen says: Jul 24, 2011. 4:16 PM
What a gorgeous pair u got there, and the idea of the dome is amazing, children always find interesting and stimulative tiny places, congrats!
luella says: Jul 23, 2011. 5:50 PM
About 25 years ago, I saw directions for constructing a cardboard geodesic dome in Sunset Magazine. I decided it would be a good project for my 4th and 5th grade special education students. They had to measure and draw the triangles; I did the cutting. Like you, I added 1" flaps around the triangles. We didn't use any squares. Then the students assembled the cardboard triangles with 1/2" #8 machine screws, washers, and nuts. Because this was a reward activity, after they finished their assignments, it took a couple of months to complete. They eagerly did their English and math assignments so they could work on the dome. The finished dome was approximately 4 feet high and 6 feet in diameter. We didn't paint ours, or put windows in it, but we left one triangle at the base open for a door. All the children (all boys) could fit inside. They took flashlights inside and used it for a reading corner the rest of the year. At the end of the year, the fire marshal ordered it taken down, but by then it has served its purpose.
jackg says: Jul 22, 2011. 12:38 PM
consider scaling to a gingerbread house size,
JWPatt says: Jul 21, 2011. 8:33 AM
Bucky, would be proud of this, its the kind of thing that he advocated.. This is what the octahedron is good for it divides evenly at the hemispheres..this is a three frequency, about thirty years ago I built this exact configuration ( not out of cardboard ) and lived in it for around 4 years, my mother moved into it after I moved out and still lives in it today.. Her highest utility bill has been under 80 dollars.. it was insulated on the outside of the shell with two inches of double foil faced urethane foam.. I like living in it better than any structure I have lived in..It was small about 900 square feet with the balcony bedroom. I plan to build one more to live in before I pass from the world.. It will be built much like this one only out of foot thick foam and shotcrete ...
Isn't wonderful how good ideas just live forever.. :) Thanks to Bucky fuller and you, your children will always see space as something different...
jackg in reply to JWPattJul 22, 2011. 12:35 PM
forgot to ask,, where your 'R' values in the double digits??
jackg in reply to JWPattJul 22, 2011. 12:34 PM
JWPatt,
would you make a 'screen' to ''hold'' the shotcrete? sounds like your HOUSE had an even temp all year round,
do you have pic's of your house??
JWPatt in reply to jackgJul 23, 2011. 5:22 PM
I would definitely use either multiple layers of poultry wire or metal lath which ever turned out to look the easiest to work with based against the cost ... The R factor of the dome was an R 16 but gained a great deal of radiant heat retained and reflected because of the double foil facing.. The one I have planned will be in the range of an R 48 optimum and realistically more like an R 40 .. We have built several tube frame domes.. and have a 9/10s tube dome mounted outside my business on concrete piers.. Its a 16' diameter.. dome.
I have pictures of the one I lived in somewhere just have to find them or go take some more..
jackg in reply to JWPattJul 24, 2011. 7:31 AM
Thanks JW,
gezz, R48 is hugh, no wonder the HVAC was so low,
may I suggest you look at a product called ''hemp-crete' .com, amazing stuff
can't wait to see the pictures
kmckay4 says: Jul 22, 2011. 12:35 PM
This is GREAT i am making one as I speak....Only this one is for my dog...Thanks a MILLION for the time you spent making yours and for all the time you took to write and share this recipe, that is so creative and detailed....Thank You....
jbarziza says: Jul 22, 2011. 8:43 AM
I haven't seen any of your other ibles, but if they're as creative and complete as this one, put 'em together and WRITE A BOOK! Very creative and your kids seem to be totally enchanted with it. Good job.
bigflash1 says: Jul 22, 2011. 6:58 AM
This is AWESOME! Lucky kids for sure to have a mom that's so creative!!!!!
kevinhannan says: Jul 22, 2011. 6:05 AM
bloomin' marvellous!
thanks for sharing and major kudos to you.
wilgubeast says: Jul 15, 2011. 12:55 PM
This is awesome! I wish I'd had a sweet playhouse like this when I still fit inside of one. Also, my favorite line in the whole thing, "I found a suitable one that people suggested homeless people use as emergency shelter." Brilliant.
Madrigorne in reply to wilgubeastJul 22, 2011. 3:56 AM
if you scale up your triangles, you can make it to fit you at any age. You deserve a play house, you have my permission to build one. Hugs to you.
supersoftdrink (author) in reply to wilgubeastJul 15, 2011. 1:39 PM
Oh! That reminds me... here's the site that had the instructions which inspired this instructable. It was linked to by some other site (which was the one that suggested its use for homeless)
http://www.fetchaphrase.com/dome/
CosmicBrambleclaw says: Jul 22, 2011. 1:40 AM
Aww cute pictures :3
UseDaGreyMatter says: Jul 21, 2011. 9:37 PM
looks great! A LABOR OF LOVE TO BE SURE!!!!!!
patron_zero says: Jul 21, 2011. 5:55 PM
Really excellent quality cardboard can be found at upper-end fine furniture retailers, mind large screen plasma-LED TV boxes are great for such purposes too but the harder to find honeycombed shipping boxes will offer your projects longer playlife and a much stronger construction.
clandestinecliche says: Jul 21, 2011. 3:40 PM
How big is this thing? I would love to make one for myself as a reading area.
grebjack says: Jul 21, 2011. 2:17 PM
I was planning to figure this out to build a planetarium with my astronomy club kids. Thanks for doing the hard work for me!
Homeofmyown says: Jul 21, 2011. 9:39 AM
Good job. Do you have an art degree? Your use of materials at hand is so smart. Very entertaining ible to read.
shenderson1 says: Jul 21, 2011. 9:21 AM
Really cool! Good instructions as well. Maybe if I get some extra time I will try...
generaljuan says: Jul 19, 2011. 3:46 PM
I see a gryphon and have one thing to say FOR THE HORDE.
on a more serious note, i really like your design. i am thinking of scaling it up and using velcro so i can make something like this for an ultra portable emergency-type shelter.
jackg in reply to generaljuanJul 21, 2011. 8:56 AM
an EMT shelter- smart idea,,if I may be so bold as to add to your idea Sir,
one could use 2 inch silvered(one side) foam, fiber glass each section trapping in an industrial velcro 'A' as a flap. 'B' glued onto the corresponding piece, the whole thing would weigh maybe 5 pounds, tape the outside with silver tape
would make a very sturdy quick shelter, for either hot or cold, rain, the base might be problematic, still a great idea,
good luck with this
spark master says: Jul 21, 2011. 8:25 AM
fabulous where did you get the original design can you post a website? I wish I has seen this when my kids were little.
jackg says: Jul 21, 2011. 8:23 AM
Very cool,
Icosahedron for the top, into a sq'ed base, love the dominoes,
also consider a dodecahedron for the top, still into a sq'ed base, again leave a panel out for a window
brilliant!!!
Kasm279 says: Jul 21, 2011. 8:19 AM
When I saw the unpainted picture of this I immediately thought soccer ball o_o
steveastrouk says: Jul 21, 2011. 7:57 AM
BRILLIANT 'ible ! Well done !
Steve
rhino says: Jul 21, 2011. 7:47 AM
I bet if you fiberglassed over the exterior, it would be pretty strong and could be used outdoors as storage or pet shelter.
whiteoakart says: Jul 21, 2011. 7:38 AM
Would you be my mom?
cairparavel says: Jul 20, 2011. 1:03 PM
How long did it take you to make the whole thing?
cairparavel says: Jul 20, 2011. 12:59 PM
Awesome!!!
flyingpuppy says: Jul 20, 2011. 9:56 AM
Bet your kids LOVE this!
l8nite says: Jul 18, 2011. 11:26 PM
this is just way cool
CatTrampoline says: Jul 18, 2011. 9:33 AM
Buckminster Fuller lives!
sunshiine says: Jul 18, 2011. 1:25 AM
Love it!
mary candy says: Jul 17, 2011. 6:56 PM
Great job!
sakkidra says: Jul 17, 2011. 12:18 PM
You did an awesome job. I love doing stuff like this for my kids. Your instructions are well done and lots of pics, good job!
seamster says: Jul 15, 2011. 4:31 PM
This rocks! I really like it.
Here's a good, cheap, and extremely useful tool to add to your arsenal if you tend to make stuff frequently out of cardboard: it's a spline rolling tool.
They're generally used to insert the rubber spline that holds screen material into window screen frames. It's like a pizza cutter with a fat plastic wheel at either end. I use mine all the time with a straight edge for quickly creasing cardboard for folding. It's a great little tool. You can get them at home stores and even Walmart.
jackie paper in reply to seamsterJul 17, 2011. 10:48 AM
Excellent Idea Seamster!
I have one of these in my shop I have never used. I am going to get it right now and put it in my paper crafting toolbox. Here i thought I was smart at re-purposing tools but this one has been staring at me along and I never thought of it. Kudos too you!
thewmas in reply to seamsterJul 17, 2011. 8:44 AM
Great Idea, Maybe a dull pizza cutter would work too, or even a sharp one to cut, but you'd need a soft backing, so not to dull.
raviolikid says: Jul 17, 2011. 10:17 AM
Wonderful design! Your instructions leave nothing to doubt. congratulations!
MercuryCrest says: Jul 17, 2011. 10:05 AM
This is a wonderful Instructable!
If I had kids, I would make this for them right now. Since I don't...Hmmmm, what excuse can a grown man come up with for building one of these...?
I know! I'll claim that it's a scale replica of a greenhouse I plan on building from scratch. :D
raviolikid in reply to MercuryCrestJul 17, 2011. 10:14 AM
I like your attitude! It's never too late to have a happy childhood!
vafnord says: Jul 17, 2011. 9:10 AM
I LOVE this. An unbelievable amount of cardboard passes through my house, AND I am a dome enthusiast. I am definitely making one of these. And I love your "rivets". The thing looks so steampunk.
cdawisconsin says: Jul 17, 2011. 8:14 AM
This is super cool =)
splazem says: Jul 16, 2011. 8:05 PM
Cool beans!
Carlsburg says: Jul 16, 2011. 6:41 PM
Scaled down it should also be great as a kennel for dogs or cat hide. Very clever instructible. My compliments.
Kiteman says: Jul 16, 2011. 5:56 AM
Wow, that is *brilliant*!
Mimikry says: Jul 15, 2011. 5:51 PM
very cool!!!
i had something like that in mind - now i don't have to figure it out on my own !
great, thanks!
PeckLauros says: Jul 15, 2011. 2:28 PM
Verry good!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
