Step 3Cut the top and bottom disks of the turbine
1. Cut a 10x10 inch square of cardboard.
2. On all four sides make a mark half way between the edges. That mark will be 5 inches from the corners on each side.
3. Use a ruler to draw lines that connect opposing 5 inch marks through the center of the square. Where these lines intersect, that's will be the center of the circle.
4. Use a compass if you have one and jab it into the center and expand it out to end of one of the radius lines. Now draw a full circle with the compass. I'm not sure school compasses are big enough to do this. An alternative might be to get a ten-inch bowl or something like that and lay it over the square and trace the lines. You can also simply eye-ball it and make an arc from the center of one side the the center of the next. You may not get a perfect circle but I don't think this is too critical for the model we are making. In the real thing it may throw off the ballance.
5. Now cut the circle.
comments
Add Comment
Add Comment
