3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cardboard Savonius Wind Turbine
Step 4Draw angle lines on the disks
Now for a little geometry. Take a look at the first image. Notice that there is an Angle A and sides a, b, and c. Side c is the line that we want the paddle to line up with. Where we draw it depends on angle a. To do a little geometry on this let's cheat and use a web-based right triangle calculator.
Make use of the following url: http://www.csgnetwork.com/righttricalc.html My side b is 5 inches (the radius of the circle) and I chose to make side a 2.25 inches. Accoding to the calculator, this makes angle A 24 degrees. You can play with this calculator by either entering side a or angle A as you experiment with different configurations.
Going with my 24 degrees configuration, make a mark along side a 2.25 inches from the center of the circle and then draw side c. Now do that with the other three radius lines.
After that is done, do the same thing with the other disk.
Notice that there are short cuts in the disk at angle A on each radius line. The pupose of these cuts is dock the paddle to the disks. The cuts should be about a half inch and should follow the path of line c.
1 comment
Jan 23, 2011. 9:45 AMIETMN says:
dude! this idea is good! would you be nice and send me the pdf file to my mail please? if so: stefymel@hotmail.com
I'll really appreciate if you send the file please!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
38
Author:rhackenb
