Step 5Attach the paddles
2. Push the axis rod down through the center of one of the disks. I suggest that you keep the side of the disk with the angles drawn facing up for easlier alignment of the paddles.
3. Push the rod through the center of the second disk with the side of the disk with the drawn angles facing down. Slid the disk up the rod to within about 8 inches of the top disk.
4. Slide the second rubber band up the rod to within an inch of the lower disk.
5. Push one of the paddles onto upper and lower disks so that the notches on the paddle dock into the angled notches on the upper and lower disks. You might want to temporarily tape the paddle into place from the top and bottom.
6. Mount the other three paddles in same way.
7. Push the rubber band on the bottom up the rod so that it sits firmly up against the lower disk.
8. Now you can tape the paddles more firmly to the lower sides of the disks (the lower sides if you don't want the tape to show. As an alternative, you could use a glue gun to glue the paddles in place. Only do this after you have finished testing the turbine in the wind and are happy with the angles of the paddles.
4
comments
Add Comment
rhackenb (author)
says:
rhackenb (author)
says:
Add Comment
