3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cardboard Shoji Screen - Room Partition
Step 4Using my left cerebral hemisphere
Mark a 2" border for the top and sides of one of the cardboard panels. Make sure you only make these marks on the printed side. You don't want to mark up the clean side of the cardboard.
I made the bottom border about 6" from the bottom. If you're making your screen taller, you will need to make the bottom border larger (higher) so that the screen will hold its rigidity. For instance, if you're making a 72" x 18" screen, make the bottom border at least 20" high.
Next separate your drawing, and place 1 half on top of one of your cardboards and start making marks so that you will know where to cover the seams of the paper. You will want to make your "seam" borders (where each paper is connected) about 1" wide, and make sure that these borders cover your paper seams.
Once you've made all your marks, lay your drawing on top again to make sure that all the seams are covered. You should be able to see all your lines through the transparency of the paper.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:tonictina
