Cardboard Tombstones
Introduction: Cardboard Tombstones
exacto knife
Elmers glue
Drywall compound
Acrylic paint: black,gray, white
Big paint brush
Detailing brush
Marine varnish( waterproofing)
Hot glue
Glue sticks
Bottle with tight lid( I use the red coffee ones they work really good Good 4 that)
Creepy Mirror decals( dollar tree)
Sand ( free)
Ziplock bags or double plastic bags
Fake flowers( dollar tree)
How to make Paper mache:
4 cups of flour
Pinch of salt
2 cups of water
2 tsp vinegar
elmers glue
Mix well until mixture resembles a thin pancake batter
How to make paper clay:
2 -3 cups of paper mache mixture
3 drywall compound
Lots and lots of recycled paper bits( you can get the at Home Depot for a couple dollars)
Mix and form a soft dough form
Refrigerate 24 hours before using
( if it's too gooey add paper bits a little at a time to bulk it up)
This tombstone was made with a total of 0.00 dollars, I had absolutely everything I used, if u do need to buy all of this would probably run you 21 dollars with out the marine varnish , marine varnish is something you should absolutely have all the time it's amazing to waterproof and a tiny bit goes a long way, and it can run in the expensive side but if u buy in small containers you can have them handy for projects like these
Step 1: Build and Structure
This one is pretty easy , in order to make a sturdy cardboard tombstones, they need "bones" to keep it upright, and to keep everything in place, so I opened up my box, added an "x"'shape on the middle , make sure to tape it down and hot glue it on both sides, I added weight on top of it just to make sure it stuck to it, once completely dry, add 2 or 3 ziplock bags full of sand inside , this will weigh your tombstone down( no more running after them to the neighbors yard) add tape to sides to seal it and get it ready for paper mache.
Step 2: Paper Mache , Clay and Details
Cover it completely , top and bottom with paper mache and newspaper strips, add the creepy mirror cling, secure it with paper mache , wait 24 hours then proceed with paper clay for details.
Now paper clay this one is amazing, I love working with this stuff, start by adding dimension for the tombstone anything you want, anything goes,
I knew I wanted to 1. frame the picture and 2. add flowers, so I started adding and molding , just remember wait 24 hours after you apply the clay so it can stay there pretty good, I then cut out RIP in cardboard and used more clay to form the letters and adhere them to
The structure, as a very last thing I added little triangle things that are gonna be used as bases for flowers I figured it's better to have everything in one. I did adhere my little base a little crooked but I fixed it with clay :).
Step 3: Paint and Varnish
This is a pretty easy one, spray paint in its entirety, I used 1 can for the whole tombstone but there's a couple little spots I can see , let it sit a couple hours, once completely dry do your marine varnish all over this will water prof your structure and you'll thank me on your first rainstorm :) add the flowers any color will do, and your done!!!!!!
****always remember to use a well ventilated area when using, paint, spray paint and or varnish*****
Now enjoy it!!!! Happy hauntings!!!!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    And thank you @ diy hacks and how to
    @sparkmaster thank you! Did not know that! Will be trying in the next tombstone!
    Try using exterior wood glue, same consistancy as White glue and does not dissolve in water once set.
    That looks really good. I like the rough stone texture that you were able to get.
