Cardboard USB Flash Drive (Packaging)
10,584
157
24
Published
Introduction: Cardboard USB Flash Drive (Packaging)
About: 22 | Howest Kortrijk | Student: Industrial Product Design | Bachelor's degree: Digital Design and Development (Devine)
For a school course called "Creativity" we had to design a cardboard packaging that can be used effectively and not just serves as packaging. From this the idea came up to make a cardboard USB stick (something you probably already have seen in some form) but never else a decent concept is thought about it. So I worked out an idea where the USB stick is part of the whole package. A light compact device that can be customized to your specific needs by using pencil, pen, stylus, ... an easy medium to transfer files and manage projects orderly.
Step 1: Materials & Tools
Since this is a simple ecologic design for a smart package, not many materials are required:
  • Standard USB Flash Drive
  • Piece of cardboard
  • Wood Glue
  • Super Glue
Used tools:
  • Lasercutter for perfect shapes (or Utility knife)
  • UV LED Printer
Used software:
  • Adobe Illustrator
Step 2: USB
First of all I stripped down the USB Flash Drive, easy when you use cheap or free gadget devices. In my case I just had to separate tree parts from each other, no extra tools needed.
Step 3: Measuring and Drawing
I started with measuring the USB-part, then made a simple drawing in my Illustartor file. Around this drawing I created my design for the cutting lines, one layer is connected with the USB-device with a crack-line. This layer will keep the device in the package before use.
After this I added some simple minimalistic print content, the device just has the brand logo and capacity on it. The package contains all the other information needed.
Step 4: Cutting the Cardboard
I used a lasercutter to make this prototype, this guarantees precise cutting and smooth edges. (It's possible to cut it with a Utility Knife but the result wouldn't be the same...) I also provided a small hole for the LED indicator on the device.
Step 5: Printing the Cardboard
To give the design a nice finish I printed some content on it, in this case I used a UV LED Printer.
Step 6: Combining the Layers Together
After every single part is finished, it's time to get them all together... As you can see, the parts fit smoothly with the USB-device. To combine the cardboard parts I use Wood Glue, this has also a very strong effect on this material. For the USB-part I use Super Glue to fix it to cardboard.
Step 7: Product in Use
A cheap and light devise that can be used to keep projects organized, there is a wide variety of memory sizes... Just take a USB-device, make a note on it, work on it with anyone, everywhere, anywhere ...
6 People Made This Project!
  • Clocks Contest
    Clocks Contest
  • Water Contest
    Water Contest
  • Creative Misuse Contest
24 Discussions
Very cool, interesting thanks for sharing!
Nice minimalist taste! Definitely looks like a complete, finished product.
Wonder why the Smurfit Kappa Logo?
As for the UV LED Printer and the Laser Cutter... Were they homemade or bought?
This was a school assignment for the company Smurfit Kappa (company which produces cardboard packaging). I used a Laser Cutter at school and UV LED Printer at a local Copy center.
Thank you so much for this awesome post. I've been looking for wooden usb packaging though this is cardboard. I'll let you know for sure as soon as I try this out.
I couldn't find this style of cardboard my cress board is so weak :-(
So we have a science fair coming up and i saw this and was like ," YESS''. But I have a question. Does it actually work?
thank you for idea "joachim_VdV"
kiss kiss
kiss kiss
kiss kiss
I like your idea of combining the product with the packaging. Your final product looks amazing! :)
