3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Designing Cardboard Furniture
  • last photo ←
Create more spaces that weren't there before, save a tonne by creating you're own furniture out of cardboard and watercolour tape.
You'll find several nifty tricks and tips here and in following instructables about how to design your own cardboard furniture.
Some pieces can be completed in a day or two, depending on your design.
I came across Eric Guiomar's DVD titled How to Design Cardboard Furniture by Vinestreetworks, then his first book, and then this instructable was born.
Here's some new techniques you can use to design uniquely shaped furniture.
New! Eric Guiomar's new pdf book part 2 is available.
Check out many French Cartonnistes personal websites below:
French Cartonnistes Websites
In this instructable, I demonstrate how I made an extremely sturdy three-storey book shelf made of six ply cardboard. Simply follow the same principles to create any design you like.
Step 1Sketch Your Design & Measure & Cut Accurately
Check out books and catalogues for inspiration. The first cupboard I planned to make was a Chinese style black and gold one. In this instructable the same methods are used for every type of object you plan to make. I will show step by step techniques of how I made a craft cupboard to store my knicks knacks.
Check out my other instructables for details on how to make your own door hinges -
http://www.instructables.com/id/How-to-Make-a-Cardboard-Hand-Puppet-Stage/
new tips and tricks for cardboard furniture:
http://www.instructables.com/id/Cardboard-Triangle-Corner-Cupboard/
So now you've figured out you basic construction. You will be surprised at the strength of your cardboard structure. This cupboard below holds up to 80kg of folders.
After 3 months its still standing!
Look for clean cardboard thrown away in electronic superstores. Large complete pieces are ideal - the size of a refrigerator or plasma tv. I clean any visible dust with hospital grade 90% alcohol. Let dry.
You will need to work out the measurements for thicknesses for each layer ON PAPER.
6-10cm is ideal space between each LAYER.
Thicker ply of cardboard is definitely going to make aa stronger cupboard or chair or table.
In one structure I used 2-ply cardboard other times 3-ply.
1 ply is all that's necessary for the shelf layers (more on this later)
When cutting the shapes of the cardboard use a simple craft knife. Slice 3-4 times over the line you've drawn without using pressure. You'll be surprised how effortless it is compared to working with WOOD.
Sharpen your knife often. I used the side of brick and its brillant.
WARNING:
Accuracy in MILLIMETRES is essential, or your structure may collapse. (Seriously.) NOTE THE DIRECTION of your cardboard. If you cut on the vertical GRAIN each piece will be stronger than if you cut a horizontal grain.
137 comments
1-40 of 137next »
Oct 10, 2011. 1:29 PMAnathematized1 says:
Does anyone know how to get Eric Guiomar's DVD? vineworks.com doesn't seem to be a valid url anymore. The only thing I've really come across is a video rental for smartflix.com.
Oct 3, 2011. 11:12 PMArtsyFartsyGirl says:
On July 3, 2011 I went to a craft museum in Los Angeles. There was an installation by an artist named Ann Weber. She had created huge "forms" from cardboard strips, tape and staples. The staples were obvious too. They had odd shapes, and some were "grouped",(The Wedding Group, all painted white) some were painted and some unpainted.
I couldn't believe my eyes that someone would use cardboard for "forms" and consider it "Art"! And she had a video showing her having her "forms" manufactured.
Just goes to show you!
Sep 20, 2011. 4:15 PMamusacchia says:
scusa è possibile avere il tutorial della libreria a spirale? è fantastica
Sep 20, 2011. 4:14 PMamusacchia says:
scusa è possibile avere il tutorial della libreria a spirale grazie....è fantastica
Aug 16, 2011. 11:46 AMvcaskey says:
I really like the YinYang shelf and have followed the link a few of you have posted hoping to find directions on how to make it. The site is in French and I don't see any directions. Anyone know where I can get instructions for this?
Sep 11, 2011. 2:30 PMajackson16 says:
If you have Google Chrome there is an option to translate the site to english.
May 27, 2011. 12:31 PMjcroasmun says:
how can get info on how the violin was made?
May 20, 2011. 8:22 PMmary candy says:
this ible is the first I saw. I was searching for furniture made with cardboard.
It's your fault , now I am a Instructables addict .
:D
Mar 6, 2011. 8:29 AMkleinjahr says:
Tres bon, very nice work. I've got a couple of old books around here on cardboard/corrugated construction, furniture and housing. I'll have to go through them again. I do remember them suggesting, for a very strong panel, to glue layers together with the corrugations of each layer at right angles to the last layer, like plywood.
Dec 22, 2010. 8:56 PMlive_corrugated says:
Thank you so much for taking the time to show your process and beautiful product. It has been inspiring to pore over this rich variety of examples by you and other artists/craftspeople. Cardboard so lends itself to a diversity of form in large scale, its just a wonder that more people haven't been working with it.
Jan 25, 2011. 3:58 PMlive_corrugated says:
Hi again Scriptone,
I created an instructable. Check it out through my profile, because it isn't coming up through a keyword search yet. Will have to get down to the bottom of that. Maybe you could offer some comments to get my next one up to speed with the average user? Or is it even about the average user? ppl on Instructables seem quite above-average.
"Cardboard book shelves, like a carpenter"
Mar 10, 2011. 3:24 AMlive_corrugated says:
Noted. Its stronger than the final photo suggests. With 20" long shelves I would feel comfortable filling it with paperbacks and a few folios.
Nov 26, 2010. 11:29 AMthepelton says:
I have an Epilog laser, and recently I decided to make a doll chair, and show it to my landlady, who also happens to run a doll sales and repair shop called the "Doll Doctor". Here is my first attempt, copying an Adirondak chair and reducing it 1/12. It's made of four pieces, the two sides, the seat and the back, and stands about 2 1/2 inches high.
Nov 29, 2010. 9:06 AMthepelton says:
Thank you very much. I'll keep that in mind.
Apr 25, 2009. 8:34 PMbobworld says:
For a 7th grade science fair project, I made a chair and bridge to get to the chair out of cardboard, inviting all to cross the bridge and have a seat. This was in 1970! My teacher gave me a D- for a grade. I was pissed! Thank you for validating my efforts. Nice stuff you have! With new inspiration from you, I may go back to drawing board after 30+ years!
Oct 28, 2010. 11:08 PMdrbill says:
Sounds to me like your teacher had some kind of problem.
Hand that rocks the cradle ya know.
Jun 17, 2010. 9:13 PMinsructoperson says:
Do you know if there is a how to on the yin yang bookshelf, that would be perfect for my bedroom!
Jun 20, 2010. 1:53 PMinsructoperson says:
Thx
May 12, 2010. 2:12 PMbob201092 says:
your products are amazing great ideas i doing a project like these u have givin me some good ideas to start with thanks
Jan 15, 2010. 9:46 PMwdlaurie says:
Where to get cardboard so that you can furnish your home? We moved recently, and these two strategies gave us more boxes than we needed:
1. Call liquor stores and ask when you can pick up discarded boxes. Since the boxes have to hold fragile/heavy items, these are good choices.
2. Drive up to behind your local shopping center where the dumpsters are. Our local RiteAid had unpacked all their Valentine's day merchandise, and they had more boxes than they could fit into 2 dumpsters. I made sure the boxes were clean/dry before I took them away.
Sep 27, 2009. 9:17 AMI like food says:
What if you put cardboard in a blender than molded it like clay?
Dec 13, 2009. 4:14 AMgreenbeanmusicmachine says:
 is there anywhere I can get a template or instructable for that spiral cd rack / shelf. It's so cool.
Oct 8, 2009. 5:02 PMmelody_yesterday says:
i would love to have the pattern for the hangers ...
is there one already online or what ?
Oct 10, 2009. 6:36 PMmelody_yesterday says:
WoW ! Scriptone!
Those are excellant !
THANKS !!!!
1-40 of 137next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
91
Author:Scriptone
