3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Designing Cardboard Furniture
Step 4Layer silhouettes on top of each other
1. Place the uncut inside silhouette on the bottom level
2. Place the middle silhouette that has struts attached
3. Finally place the top level which will be the FRONT OF STRUCTURE
4. Put weights to add slight pressure so you can tape the pieces more tightly. I used coloured sand in zip lock bags.
A. Using very STICKY DUCT TAPE attach the stuts at the top, bottom, middle. This takes a while to do, but its relaxing exercise.
Warning, you must be very accurate in measuring and assembling at this stage or structure may collapse because edges do not meet exactly. The other main cause of collaspe is if the ply is less than 2 or 3 ply or the direction of the stripes on the cardboard for the sides are horizontal instead of vertical.
With my first Chinese cupboard, I had problems because of a slight measurement off here and there. Use a FILE or RASP to even edges sticking out.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
91
Author:Scriptone
