loading
Step 6: Finishing the Design Phase
Now we need to connect the snowflake to the inner most arc segments, otherwise it will fall out when laser cut.  Add four little curves connecting the top and bottom of the snowflake to the ends of the inner arcs.  Delete the resulting small segments at the top and bottom of the snowflake.  Then, add a half circle to the top of the outer ring, delete the small arc segment of the main circle, then add a small circle centered in that area.  This will be the tie point to hang the wind spinner.  You are now done with the design portion!
I have Silhouette Cameo. Can you provide a SVG version of your design?
wow <br>i do not have &quot;laser&quot; cutter <br>but i have cricut!
I love that snowflake! Perfect :)
About This Instructable
6,522views
31favorites
License:
More by JoeGadget:Nascar Cribbage Board Hard Boiled Eggs With Bacon INSIDE Easter Egg Stands
Add instructable to:
