Do you have a Fog machine? Do you use it infrequently? Have you noticed it's output decrease? Here's some simple cleaning tips you can use to keep your fog machine working well.
Step 1Empty the fluid tank
Most fog machines that are cheap have a built in fluid tank so you will have to empty it. But wait, don't throw away the fluid. If the fluid is still clear (or it's original color) and doesn't have any debris in it, you can use it again. I recommend getting a small Nalgene container to store the fluid in. A 500ml container is usually about the right size and should only cost a couple of dollars at a camping / outdoors store. In Canada we have Mountain Equipment Co-op and Campers Village which are the best places to find a container like this. As a side note, if the fluid is clear but has debris in it, you can pour the fluid through a disposable coffee filter to remove the debris.
Anyone have one of these machines, and/or know where to buy a (correct) pump for it? When this machine works, it seems to work better than MOST foggers I've seen (sounds like a jet engine when it goes off, and makes LOTS of fog!).
I'm pretty sure stealing a pump from a smaller machine will not provide anywhere near enough juice to supply the machine properly...Any thoughts/help would be really appreciated.
Thanks, Joe
When speaking with a pro that sell foggers and fog fluid, he offered this advise to home haunters- Buy cheap foggers and throw them way every year. He stresses that our foggers weren't designed to be used outdoor in the cold like most of us use them. He also said to leave fog fluid in the units when storing them.
I also have many pumps, that for whatever reason dont do anything except make a buzzing noise that produces no fog. I tried cleaning them and it just seems to make it worse.
My son is a died in the wool dumpster rescuer, he came home with 4 fog machines, 2 worked fine but 2 dont. We took the machines apart and removed the copper tube from the pump, the pumps are getting fluid to that point. But how do I unclog/clean the small tube? I thought about compressed air but the tube is way 2 small, blowing thru them has the same problem but they do feel clogged.
Any ideas ?
As a side note: Ive used citronella lamp oil in one of my foggers during the summer to help combat misquittos. I was a little leary at first because it IS a FLAMMABLE liquid so I had it set on a concrete pad but after many evenings of use there was never a problem and it had the desired effect on the little winged vampires ..
It need a remote(wired)
walmart sell it for $5
it's the same machine I have.
Nicely done I'm A firm believer that even cheaply made or "disposable" products
can last far longer then intended, if you take the time to do the maintenance needed, ' that is, if you you know what care is needed for any given product well now my little fogger is as happy and ready for use as my other toys. (and tools)
Anyway Thank you for a fine Instructable .
SNAP....
