3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Care and Feeding of Fog Machines
Do you have a Fog machine? Do you use it infrequently? Have you noticed it's output decrease? Here's some simple cleaning tips you can use to keep your fog machine working well.
Step 1Empty the fluid tank
Most fog machines that are cheap have a built in fluid tank so you will have to empty it. But wait, don't throw away the fluid. If the fluid is still clear (or it's original color) and doesn't have any debris in it, you can use it again. I recommend getting a small Nalgene container to store the fluid in. A 500ml container is usually about the right size and should only cost a couple of dollars at a camping / outdoors store. In Canada we have Mountain Equipment Co-op and Campers Village which are the best places to find a container like this. As a side note, if the fluid is clear but has debris in it, you can pour the fluid through a disposable coffee filter to remove the debris.
39 comments
Jun 21, 2007. 8:09 PMBlueFusion says:
Cool. Interesting that you say minerals damage the fogger. This may be what reduces its output over time, as the fog juice is... MINERAL OIL! And the vapour would be mildly acidic, so, yes, avoid inhaling it as you don't want to burn the inside of your lungs.
Jun 26, 2007. 6:33 AMBlueFusion says:
Whoa. You either know what you're talking about or are very good bluffer. I believe you. OK thanks, I'll keep that in mind.
May 25, 2012. 1:14 PM_soapy_ says:
He's not bluffing. The fog machines generally in use use a water/glycol (aka glycerine) mix that is far safer - non-flammable, and doesn't kill you by inhalation.
Oct 28, 2008. 9:45 PMfantacmet says:
About a month ago I picked up a 700+ watt Fog Machine from the local thrift store for 5 bucks without a remote. It even had a jug of fog juice. ifigured for 5 bcks can't beat that. Local department store had fog machines of the samemanufacturer(smaller ones), and they were half off so I picked one up for 15 bucks. So I used the remote on the big one and it works. Being a bit of an electronics guru I opened the remote, and it's so simple. Soon, I will be making an instructable on making your own remote. I have a different instructable I need to make first to make a piece of equipment needed to make the remote. Stay tuned and remember my name. I promise the equipment and a remote within 2 weeks.
May 25, 2012. 1:11 PM_soapy_ says:
Are you still planning the fogger instructable?
Nov 29, 2011. 10:36 AMlilwheeler21 says:
I have a Eliminator E-119. Bought it last year after Christmas time, maybe used it a couple times. I had it stored in a box in my closet, got it out filled it up, lights come on!....nothing...what to do?
Oct 24, 2011. 11:01 PMMOPARJOE says:
I have an American DJ F-500 fog machine. It is not working (again), and seems like it may/must be the pump this time (heat unit went bad last time, and was fixed under warranty). The machine is now considered old/obsolete, and parts are not available.
Anyone have one of these machines, and/or know where to buy a (correct) pump for it? When this machine works, it seems to work better than MOST foggers I've seen (sounds like a jet engine when it goes off, and makes LOTS of fog!).
I'm pretty sure stealing a pump from a smaller machine will not provide anywhere near enough juice to supply the machine properly...Any thoughts/help would be really appreciated.
Thanks, Joe
Oct 24, 2011. 5:45 AMgoliwa says:
Perhaps a stupid question but... why do you dilute the vinegar? Wouldn't a straight vinegar solution, being stronger, do a better job with fewer cleaning cycles needed? Yes, it's acidic, but the fogger parts wouldn't be exposed to it for very long and a good rince cycle would certainly clear it out.
Sep 5, 2011. 10:14 PMshootnchef says:
Ok what will it take to convert a smoke machine to a hazer? I have many smoke machines, some good quality and some cheap ones that I can fiddle with.
Feb 5, 2011. 5:45 PMdarkride says:
If you use vinegar, you MUST get it all out. I've run vinegar and water through a couple foggers that worked fine and found they were dead the next year. The vinegar will swell the rubber parts in the pump and render it useless if the slightest bit of vinegar remains in the lines.
When speaking with a pro that sell foggers and fog fluid, he offered this advise to home haunters- Buy cheap foggers and throw them way every year. He stresses that our foggers weren't designed to be used outdoor in the cold like most of us use them. He also said to leave fog fluid in the units when storing them.
Oct 24, 2010. 10:12 AMjdiddley says:
Good tutorial. Just exactly what I was looking for. Thanks!
Mar 1, 2010. 2:30 PMSmokedogg says:
Where can I get those small copper pipes that also have that little ball thingy at the end of the tube. I have searched EVERYWHERE. I have found the tubes at I believe it was the American DJ site, but I only got the tube, without the lil ball thingy and the nut to screw it on. So it was pointless and a waste of money. I have several tubes where the fog fluid is pouring/leaking out of. Towards each end of the nut, the copper seems to be striped away about a 1/4 inch up. Thats where its leaking from.
I also have many pumps, that for whatever reason dont do anything except make a buzzing noise that produces no fog. I tried cleaning them and it just seems to make it worse.
Mar 8, 2010. 9:21 PMSmokedogg says:
Thank for replying...I have tried searcjing McMaster and Grainger and couldnt find them. This place Gregg Dist. carries these? If it is, what page would I have to look at in its Catalog? I just googled Gregg Distributers and clocked on the 1st site which brought me to the catalog.
Nov 13, 2009. 7:06 PMl8nite says:
How do you clean the small copper pipe that goes thru the heater element ?
 My son is a died in the wool dumpster rescuer, he came home with 4 fog machines, 2 worked fine but 2 dont. We took the machines apart and removed the copper tube from the pump, the pumps are getting fluid to that point. But how do I unclog/clean the small tube? I thought about compressed air but the tube is way 2 small, blowing thru them has the same problem but they do feel clogged.
 Any ideas ?
 As a side note: Ive used citronella lamp oil in one of my foggers during the summer to help combat misquittos. I was a little leary at first because it IS a FLAMMABLE liquid so I had it set on a concrete pad but after many evenings of use there was never a problem and it had the desired effect on the little winged vampires ..
May 5, 2009. 5:22 AM3614tracy says:
I have a fog machine that is my son's, it says that I can only use the distributor fog juice. The name of the machine is not on the machine, but the model # is SPEC-80, what should I do?
Nov 5, 2009. 3:26 PMmman1506 says:
 i have a fog machine and when i used a general brand it worked better!
Sep 6, 2009. 1:17 PMlindadi says:
I have two foggers bought them both brand new a few years ago. had them in storage for about two years. wanted to use them last year and as i put the fog juice in and ready to use it started leaking out of the bottom. Is there any way to save them?
Jun 16, 2008. 9:05 AMRobottttt says:
I recently received a fog machine and tried it out with some new fog juice. When I turned it on there was no noise. After a few minutes there was a little bit of fog that seeped out but then it stopped. The machine heated up but produced no fog. Is my pump shot?
Oct 31, 2008. 7:03 AMguymark says:
It sounds as though the pump has seized - it happens usually when people store the machine empty (always store it with PLENTY of fluid in the tank) If so, all is not lost if you are prepared to do a bit of careful disassembly. You do not need to know any electronics - just basic disassembly skills. Incidentally, I note you say a little fog came out (stuff left in the pipes) so we know the fuse hasn't gone - as the heater must be working. Assuming the remote isn't damaged (broken wire), then a seized pump sounds like the problem. Remove case and you will find usually attached to the tank, the motor (in cheaper units, a car washer pump effort). Having emptied the tank (save the fluid), remove the pipe leaving the pump - the one that goes to the heating chamber. You might just possibly need to unsolder the two wires feeding it - but usually they are long enough to let you remove the pump from the machine and get it on your bench. If you DO unsolder the wires, unless you know it is fed with AC and rectified on board (a lot do), then make a note of what wire goes where, a pump motor running backwards is not what you are after. With the pump isolated, you will usually find, with a bit of pulling and wriggling, you can pull the motor part, out of the plastic housing, and in doing so open the pump up. Depending on the model, the impeller will have been left behind - or may still be on the end of the motor. No problem either way as if the impeller came off, it is usually easier than you think to re-align shaft and hole when you put it back together. All you need do at this stage, is turn the motor spindle by hand. If REALLY stiff, use a pair of plier and try to make TINY turns in BOTH directions until you get SOME movement. Once you have some movement, I would suggest you "wash" the area with methylated spirits or other solvent. Although this is NOT usually a good idea as it strips away any lubricant - it is ok here - as the lubricant has already long since failed - hence the seizure. One advantage of removing the wires is that you can connect the motor upto anything from about 4.5v and upwards to get the thing running - while the machine is all in bits. Now drip some decent quality oil in around the shaft end and leave the motor running slowly (not on 12v) for some time (about a minute). This will give the motor a chance to dislodge and more "grot" around the bearings and let it come out the other end as "dirty oil". Better out than in :) If you are NOT wiring the motor upto a battery, just keep on turning the shaft by fingers until you are convinced you have as much "grotty oil" out as you are going to get. Turn motor other way up and do the same to the bearing at the other end. At this stage of the game, you should have a free-running happy motor Carefully re-assemble the motor back into the pump housing - aligning the spindle and impeller is often "automatic" as there is no other place for them to be other than aligned. Re-fit the pipe and then press back / connect back the pump to the tank - in almost all the home user machines, this is a push-fit into the side of the tank through a big rubber grommet. Re-assemble case, fill tank with fluid. If you can - WHILE STILL UNPLUGGED - put your mouth to the fluid tank and blow quite hard - you will force some of the fluid into the pump to help prime it. Not essential usually, but it just saves you getting all anxious waiting to see if it will manage to prime itself. Plug in and test. If it all works well, then leave it plugged in for half an hour or so and fire off a jet of smoke every now and again - and before you switch it off, make sure the machine has had a few good LONG blasts - 30 seconds or so. By now, your pump should be fairly happy to do another few years work, but please remember, ALWAYS leave your machine stored FULL. (If after re-assembling the pump doesn't work (but did if/when you applied voltage directly), than have a word with a friend who likes messing about with electronics and see if he can find why the motor is getting no power). Hope that helps - it is almost faster to do the work than it is to write about it - very simple really, but broke it down into a mini guide to make things easier. Mark
Jun 17, 2008. 4:13 AMRobottttt says:
My machine only has one switch on it so I can't heat it up and push another switch to start the fog. When I tried to get it to work I just turned it on and left if for about an hour and nothing, except for the few wisps near the beginning.
Jun 18, 2008. 7:32 AMRobottttt says:
I received the machine from a friend and there was no remote included with it. The machine is called "The Fog Machine" TM by Zaixing Electronics. Is the switch that I am pressing just turning on the heater? This thing is driving me crazy.
Nov 5, 2009. 2:05 PMac1D says:
"the fog machine" is available in grey(silver) and black, sold at walmart for $25
It need a remote(wired)
walmart sell it for $5
it's the same machine I have.
Oct 11, 2008. 2:36 PMThe_pyrogeek says:
Just go and buy a new controller remote. They're out around Halloween, or you can get them online, for anywhere from $10 to $15 dollars. Good luck!
Oct 19, 2008. 5:30 PMtbearsangel says:
i recieved "the fog machine" from a friend. we plugged it in and nothing has happend. it has fluid. and the little green light never comes on. it makes no noise either, is this thing blown ya think or what should I check? I already checked the fuse in the back it's fine. I flushed it with hot water. dried it out and put new solution in. any ideas? does anyone have a manual on this thing?
Oct 2, 2008. 7:42 AMflybabytina says:
My Fog Machine thanks you! You have saved it from the grave! We did end up buying a Bubble Fogger this year too, and it sure is cool! It only has 1 switch to turn it on and off and WOW does it pump out the fog constantly! The one I saved has a remote AND the main power switch, you can make fog for about a minute and then it has to heat up for about a minute before you can make fog again. Thanks again for saving my fog machine!!! BTW, my Fog Juice says it is water based.....
Nov 4, 2007. 8:38 PMzieak says:
I'll be back reading this when i set aside time to work on my fog machine. Thank you!
Oct 23, 2007. 2:28 PMwoofboy111 says:
I bought a fog machine last year for Halloween. The instructions that came with it said absolutely nothing about emptying the fog solution out while in storage. I got my fog machine out yesterday getting it ready for Halloween and it won't make any fog. I plug it in, heat it up, and press the button but no fog comes out. The little ready light illuminates, but that's it. I remember last year the machine would make a noise when the button was pressed, but this year nothing. My dianosis is that the pump that brings up the fog juice died... I'm angry.
Oct 27, 2007. 4:35 PMwoofboy111 says:
I took the cover off of my fog machine and found out what the problem with my machine was. The fog intake tube has a hole in it. If I cover up the hole, the suction works and it makes fog!!! I need to go to an aquarium store and get a new tube tomorrow!
Oct 22, 2007. 5:02 PMSNAP says:
Thanx Tiller:
Nicely done I'm A firm believer that even cheaply made or "disposable" products
can last far longer then intended, if you take the time to do the maintenance needed, ' that is, if you you know what care is needed for any given product well now my little fogger is as happy and ready for use as my other toys. (and tools)
Anyway Thank you for a fine Instructable .
SNAP....
Jun 15, 2007. 9:28 PMandrew101 says:
its pretty basic but still good instructable
May 13, 2007. 12:59 PMcanida says:
This looks like the beginnings of a very useful Instructable, but it needs pictures. Please republish it after you've added pictures.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Tiller
