3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Care and Feeding of Fog Machines
Step 2Clean the Fogger vaporizing tube
Prep: Mix a solution of white vinegar and distilled water (this is the cleaning solution) the ratio is 1 part vinegar to 8 parts water, which is close enough to 2 tablespoons of vinegar in a 1C of distilled water. This should be enough cleaner for 1 machine and still keep the pump happy.
Why distilled water? Well distilled water has it's minerals removed. Minerals are bad for fog machines as they tend to coat the inside of the tube, reducing it's diameter and therfore reducing the fogger's output.
Rinse the Fluid tank out with distilled water.
Pour the cleaning solution into the fluid tank.
Take the fogger outside.
Plug in the fogger and allow it to heat up.
When the fogger is ready, run it until it stops. Try and avoid inhaling the vapor, I'm sure it's bad for you. Repeat until you run out of solution or patience. I would estimate that 10 cycles should be enough.
The output should start off as thick white smoke and slowly become a very thin haze over the many cycles.
Unplug the fogger and rinse the fluid tank out with distilled water.
Refill the tank with distilled water. About a half cup if you're going to use the fogger for fogging soon or about a half tank if you plan on storing the unit.
Take the fogger outside again (If you're not already there).
Plug the fogger in and allow it to heat up.
When the fogger is ready, run it until it stops. Try and avoid inhaling the vapor , I'm sure it's bad for you. Repeat at least 5 times. You should do more cycles if it still smells like vinegar. You have to get all the vinegar out of the fogger.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Tiller
