Step 4Other Tips and Tricks.
If you use your fogger on a regular basis, I have found that monthly cleanings will greatly increase it's life. I maintain an attraction where 2 small foggers are used constantly and if I do regular maintenance I can get over a year out of a fogger, whereas if I don't we've replaced them in less than 8 months.
You can shoot fog through a hose to get fog into tight places you can't get the machine into. A Dryer vent hose works best, it is about 4" in diameter and cheap. You don't need the fancy metal ones, the basic white plastic ones work and you can spray paint them to match the surrounding area. The one big thing to remember is not to seal the hose to the machine. When Fog exits the machine it needs to mix with air otherwise it quickly becomes liquid again and will drip out of the hose. Leave at least a 1" air gap between the hose and machine. I have left up to a 4" gap and still managed to get the fog to all go through the tube.
Want low lying fog (like for a grave yard scene at Halloween?). It's pretty easy. Google "Fog Chiller" and you will find lots of projects on line. I will post an instructable when I get mine finished
Add Comment
