This is a description of how to make a cargo trailer that attaches to the rear hub of a typical bicycle. The two main parts are the trailer itself and the hitch which is permanently attached to the bicycle. The relatively heavy "core" (near the axle) of the trailer was made from wood and common steel bracing and mechanical fasteners. Attached to the core is a system of aluminum pieces that comprise the main "basket" of the trailer. Most all the aluminum can be joined with woodscrews (to the core) and stainless bolts and nuts (for aluminum-only joints). I finished the wood with polyurethane and filled annoying gaps with epoxy paste filler. All the above parts can be found at a typical hardware store.
I also used certain recycled materials and added optional features using special new materials. I used a piece of tubular steel from an old ironing board (leg) as the angled connection between the bicycle hitch and the trailer core. I used a steel bar from an old exercise machine in the hitch, but that could be purchase easily. Also, I left space open in the lower portion of the core for a set of three batteries since I would connect my trailer to my electric bike. I see electric assist as a luxury, not a necessity. The wheels are 20" diameter (from recycled BMX bikes), but can really be any size you like, since the main body can be built to conform to any size wheel you have laying around. Two recycled backpack frames and some stretch-cords were used as a cargo lids, but these, like the batteries, are optional. I found a $10 grill cover that can be used as a stataionary cover as well as adapted to be used as a cover while using.
The aluminum was the most expensive part of this project and also added to the difficulty in assembly since it requires the drilling of many holes, some preferrably with a small drill press. Other that that, only typical hand tools are needed.
Remove these ads by
Signing UpStep 1Make the hitch part that will permanently attach to the bike
The U-joint is to the left of the end of the white tube in the second picture. It consists of a flat steel hardware piece bent into a "U" shape to fit around the steel tube. This allows the trailer to pivot left and right at the point near the back of the bicycle. It gets the added feature of rotation (needed when turning while the bike is not in line with the trailer, say at the bottom of a hill) by being connected to the triagular steel support by a relatively loose-fitting special single nut and bolt that screws together to form a small shaft (I'll update with a closeup soon). The white tube pivots side to side using a silver clevis pin connection.
In my case, the reasoning for using the steel tube that slids inside the aluminum tube (to form a variable-length extension) was to accommodate use with bikes with smaller-diameter tires, assuming you want the pivot point to still be at the back of the bike. Note that putting the pivot point at the rear of the bike is not necessary, but it keeps the bike from rubbing against the trailer in really sharp turns when using the relatively short(white) trailer-arm length that I chose. I liked the idea of having a minimal amount of distance between the bike and the trialer, thus reducing the over length of the bike-trailer unit. You can choose a longer trailer arm with more angle as a replacement - this is what typical retail trailers use.
Note the use of thick gauge electrical cord (with coiled plastic protection) for the optional batteries - this reduced the voltage drop.
So, you may be concerned that the hitch may get torqued off the bike frame in sharp turns. Well, that depends on how lucky you are in being able to use strong bolts in enought key areas in the area around the frame of your bike. I was lucky. I may add a closeup showing the exact bolt areas for my bike, but yours will likely be different. The idea is to bolt the hitch tightly to the frame, as close to the hub as possible. I was lucky in that I can still accommodate an old-fashioned bike rack/hub connection. I still need to remove two small bolts to change my back wheel though - a little hassle, but not a big deal.
11
comments
Add Comment
CameronSS
says:
CameronSS
says:
Add Comment
