I have a '99 Chevy Tahoe, and those are the measurements I'll give. This concept should be easily adaptable to any SUV, maybe a station wagon, possibly even a pickup truck but the platform would have to be much longer and well-secured.
Remove these ads by
Signing UpStep 1Supplies
Parts:
- 2 x 3/4" plywood sheet, 48" (width) by 48" (depth) -- I was able to buy one 4' by 8' sheet and cut it in half.
- 4 x 48" (depth) 2.25"x1.5" slotted angle iron
- 2 x sets of "Appliance Rollers"
- 30 x #8 x 5/8" screws -- you may need more or fewer depending on the length of your cargo area
- 10 x washers to fit the #8 screws -- you may need more or fewer
- 10 x 1/2" long bolts, with rounded heads, not hex, each with washer and lock nut -- you may need more or fewer
- 1 2" long bolt; 1/4" or 3/8" diameter
Tools:
- Eye protection and gloves, sensible clothing
- Pencil for marking measurements and screw hole locations
- Measuring tape
- Philips head screwdriver
- Socket wrench with socket to fit the lock nuts
- Circular saw, table saw, or other wood saw with a blade to cut plywood
- Drill with 1/2" bit for "stop" hole, 5/64" bit for screw pilot hole, and Phillips screwdriver bit
- Metal cutting saw, hacksaw -- possibly optional
- Angle grinder -- possibly optional, but I strongly recommend it
- A pair of clamps if you're going to be using an angle grinder or if you're going to be making any precise circular saw cuts, or for many other uses.
- Router if you've got access to one (lucky you)
put a short carriage bolt down through the top platform, so that it's inside the cavity between the boards. Place this hole as close to the angle iron as possible, near the back(of the rack... this would be towards the front of the car I guess)
On the side, take a long-ish bolt and fasten it through the holes of of the angle. they too should be protruding into the cavity, but instead will be horizontal.
Now, what will happen is that the vertical carriage bolt will hit the long bolt and make it stop. A carriage bolt is suggested b/c they leave a rounded top as opposed to the exposed edges of a normal bolt.
The stops are adjustable by moving the long bolt along the angle iron.
crude ascii drawing
|| is the carriage bolt
== is the long bolt
vv and is the plywood
vvvvvvvv||vvvvvvvvvvvvvvvvvvvvvv||vvvvvvv
|_ ====||=== ===||====_|
This would allow for easy removal of the top board, to get at the base, to unbolt the base from the bed. Terrific, thank you!
Now, *fast* stops might cause splintering or even tearing out of the top bolt. Not a problem for me, but something others might need to consider. It's probably possible to glue/screw/etc another piece of wood underneath the bolt, but not deep enough to it intersects the cross bolt, in order to reinforce the hole.
