Step 2Build the base
This is a good place to stop and make sure that you have the measurements correct. Try to slide the board into your "bed," oriented properly, and make sure it goes in without a fight. When you're finished, the whole thing will be just a touch wider than the base.
Put one board (the top board) to the side. You'll only be working on the base at first.
2) On the base plywood board, measure 3 straight lines from forward to backward, making sure you're orienting it as it will be in the "bed." Take several measurements from the side of the board, at each end, in the middle, etc, so that you know you have a very straight line. Use a line 4" over from each side and at the center line. Trace these straight lines--I used the angle iron because it was handy.
3) Attaching the rollers:
Take out your "appliance rollers" and unscrew the screw/wing nut that holds the two pieces together. You now have 8 individual rollers, each with a long tail. You will put these in place by lining up the tail with the line you have drawn. Line up the tail, and put a mark for a screwhole at each extreme end of the slots (one at the close end of the close slot, one at the far end of the far slot), and a mark at the middle of the middle slot.
Mark screwholes to put one roller in each corner, and three rollers along the center line (that's a total of 7). Alternatively, you could put rollers in each corner, and in a diamond shape in the center of the base; this will require more elaborate measurements.
Once you have carefully marked the screwholes, (use eye protection) carefully drill a pilot hole at each mark.
Now line your appliance rollers back up in their places, and use a screw per pilot hole. Your rollers are in place.
Add Comment
