Step 3Put in the retaining angle irons on each side
Cut your angle iron so that it is the length of your "bed" (angle grinder, hacksaw, other metal saw); you may also want to round the edges with an angle grinder or other metal saw. I certainly did; I know I'll scrape myself on the edges if they're left sharp.
2) Fit one slotted angle iron up against the each side (left and right) of the plywood base, with the short side of the angle iron up against the bottom of the base. Clamp the iron in place, and use a screw with a washer about every foot to screw it down. Your base now has vertical edges.
3) Again on each side (left and right), fit a second slotted angle iron up against the first; bolt them together such that the vertical side is about 3" tall. Use your short hex bolts, a washer, and a lock nut about every foot. I put the top angle iron on the inside on each side, as I ended up sanding/rounding the top board such that it is slightly more narrow than the bottom board.
Add Comment
