Getting the best optics in the world comes at a hefty price. A Zeiss prime lens for the Cannon EOS system will easily cost $500. Luckily, some older lens designs from a discontinued camera using an obsolete film format can be had for a song.....$12 to be exact [Thank You Surplushed.com].
The Carl Zeiss Tessar we use in this instructable was originally destined for a Contaflex 126 camera. The Tessar design is over 100 years old so it has stood the test of time. In this Instructable, we'll adapt it to fit The Canon EOS system type cameras...35mm, digital or APS types. Since I have all three types...its a win, win, win!
Remove these ads by
Signing UpStep 1Stuff You Will Need
1. Carl Zeiss Tessar 45mm f2.8 lens.
2. One Canon EOS body cap.
3. Rotary Tool with associated bits.
4. Two part epoxy adhesive (I used the 5 minute variety).
5. Flat black paint.
6. Dental floss.
7. Cyanoacrylate glue (super glue).
8. Paper clips.
9. Wire cutters.
10. Two small rare earth magnets.
AV
One question--any worries about the proximity of the strong magnetic field from the rare-earth magnet, to the digital electronics of the camera?
I never really thought too much about that! I love rare earth magnets and try to incorperate them into projects just because they are as close to magic as you can get on this astral plane (although peizoelectric crystals are a close second). The memory of most digital cameras (including mine) is flash memory. That is not affected by magnetic fields. It is an electronic type of memory, not a magnetic like a floppy disc or your hard drive.
However, a magnetic field moving through wires and other electrical components of the camera can induce an electrical current much like a generator. This voltage could in theory screw something up in the camera. Luckily, the magnetic field strength diminishes rapidly (the inverse cube law). Even the short distance from the lens to the camera body would significantly diminish the mangetic field.
I'm not sure if modern cameras have any sort of shielding in them to prevent stray current of this type. Most military equipment has some degree of shielding against electromagnetic pulse you get from nuclear weapons. However, the best defense is usually good design in the first place.
Any who, I'm not worrying too much about the magnets, but I won't bring my camera into my next MRI!
with the speed you would be removing the lens, the field even at close proximity would only be in the order of a few millivolts. definitely not enough to bother a ccd or any type of flash memory.
Surplus Shed (http://surplushed.com) has a wide variety of excess, used, surplus optical items. They have actual camera lenses like the one I used here, industrial lenses like copier, typesetting lenses and they also have raw optical elements (if you are good with optical design).
Basically, lots of cool stuff. You are limited only by your imagination. None cost too much...at least when compared to thier original price.
I'm looking hard at a medium format zoom lens to attach to my Bronica or Kiev 60.
If you don't like dental floss, epoxy and magnets....do yourself a favor and don't look at any of my other Instructables!
I'm sorry about the quality of the example photos...the instructable uploader does not like large files. I'll upload some onto my Flickr account and include the link in the Instructable so you can judge the quality without much compression...I shoot in Jpeg mode so thier is always some loss.
http://www.flickr.com/photos/21721108@N00/sets/72157625877439142/
http://www.sourcingmap.com/three-colors-camera-plastic-pop-flash-diffuser-p-93008.html
I have a Canon FD 50mm f1.4 with the anti reflective coating that is failing in a serious way. The softness it adds when blasted wide open is ethereal. I wouldn't fix it if I could!
They range from $18.00 to 45.00 delivered to your door.
Oh joy! I thought my Canon FD lenses were all ornaments, but now I shoot wildlife with a 30 year old FD Sigma 600mm catadioptric which on my Sony NEX camera is the 35mm film equivalent of a 1000mm telephoto
BTW, your FD kit will work great on an A-1 or T-90.
Shelf number two from the bottom is dedicated to Eastern European cameras.
http://www.instructables.com/id/Bring-Your-Polaroid-I-Zone-Camera-Back-From-the-De/
Can you upload high resolution pictures so we can see how the pictures turn out? The previews look great but are too small to get the picture (no pun intended)
Wouldn't it have been better to get a CZ lens with a manual focusing ring though? Would have been a bit more, but you'd get a lot more function out of it.
Focusing CZ lenses start to get into some serious money! My motto is: "The best is easy, the good enough is difficult!"
