Carry a FIRESTEEL (R) on Your Keychain
Introduction: Carry a FIRESTEEL (R) on Your Keychain
This is a FIRESTEEL (R). You use it just like a flint and steel. You scrape the FIRESTEEL (R) with either a knife blade or hacksaw blade, or the scrapper you can buy from the website. To see more about FIRESTEEL (R) go to There is a video that will show you how the FIRESTEEL (R) works and why you should carry one with you at all times... FIRESTEEL (R) comes in an assortment of sizes to fit your needs.
And here in lies the problem. I could not find a way of carrying a FIRESTEEL (R) on my keychain, so I made an Instructable to show you how... This is my first attempt at an Instructable, but hopefully NOT my last...
Step 1: Supplies Needed
You will need the following supplies:
Ring Terminal (Electrical Dept Home Improvement Store)
Needle Nose Pliers
Electricians Tool (Crimper)
Heat Shrink Tubing (Electrical Dept Home Improvement Store)
Step 2: Step 1. Remove Plastic
Step 1. Use the Needle Nose pliers to pull off the plastic covering of the Ring Terminal
Step 3: Step 2. Spread Open Connector
Step 2. Use the Needle Nose pliers to spread open the Ring Terminal connector. Be sure to open the connector wide enough to hold the FIRESTEEL (R).
Step 4: Step 3. Apply Epoxy
Step 3. Mix the Epoxy according to instructions and apply a generous amount of Epoxy to the open Ring Terminal
Step 5: Step 4. Set and Crimp
Step 4. Insert the FIRESTEEL (R) into the Epoxy. Allow to dry according to instructions on the Epoxy. Use the Electricians tool to crimp close the ring terminal connector around the FIRESTEEL (R).
Step 6: Step 5. Heat Shrink Tubing ~ Finished
Step 5. Pull the Heat Shrink Tubing over the constructed assembly. Use the lighter to shrink the tubing and your done.
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    why make one when you can buy a knife with one attached for free?
    ring terminals will not last long  almost all of them are made of soft copper,  I tryed this and it lasted about a month, I snagged it on a tree limb and it broke off..
    Can anyone tell me what it is that survivalists have against lighters? It seems like a Bic lighter should be like the Holy Grail of survivalist fire-starting tools. But nooo, heaven forbid. They all want to light magnesium shavings by striking their survival knife against a flint. :)
    lighters are much more fragile than firesteel, and usually don't work when wet. they have a much less chance of lighting a fire than firesteel (firesteel is hotter) plus they run out faster. the only reason lighters are what people carry around instead of firesteel is that lighters are much more controlled, giving off a small flame that is sustained, instead of a large puff of sparks.
    its also very difficult to use in the slightest wind
    You can, however, get windproof lighters. Its basically a mini blowtorch, meaning it burns really hot (>1000C) and is almost completely windproof.
    If you have ever been in the wild, you would know that a lighter will run out just when you need it the most. fire steel does not run out of propellant...I have a piece of flint that I carried for a lot of years (40 or more)and it still works when I need it.. Go on a hunting or camping trip to Alaska where it is always below zero to find out what I'am talking about or even Montana, Idaho, Colorado in the winter or late fall.
    I can see the problem in extremely low temperatures. You have a good point there. Gas lighters might not work so well. As for running out when you need them the most, notice I specified "Bic." If you have even had a Bic lighter run out when you needed it the most, then I suppose those other 999 fires weren't very important? :P
    I smoke so I use lighters all the time ,They run out at the most inopportune times. If you let them get cold they won't light. So to be sure that I have something dependable at all times I carry a flint and I usually can find a piece of flint in the mountains.......or desert lands ( Sand conducts heat but doesn't hold the heat at night..) I would like to get a length of fire steel to try Ps try to light a fire with a "bic" in a 30 or 40 mile per hour wind Even with flint it is hard....... GOOD LUCK with your "bic" , I'll keep my flint and maybe a chunk of fire steel also....
