3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Carry any Bottle with a JUG KNOT Handle
Tie a JUG KNOT around a water bottle, soda bottle, or aluminum bottle to make a secure carrying strap.
Re-purpose any container into a reusable water bottle by adding a convenient carrying strap. This Instructable will demonstrate how to tie a JUG knot which like its name suggests, is meant to properly secure around the neck of a container.
With some cord and the knowledge of this knot, you will be able add a handle, lanyard, or carabiner loop to any of your favorite beverages to carry them on the go.
It works perfectly for those disposable water bottles, and who knows, once you add some colorful cord to the plain old clear water bottle you just might be inclined to refill it and use it again.
(Check out pictures 4&5 below)
In addition to plastic beverage bottles like pop, water and sports drinks, you can turn those rugged aluminum beer bottles into a backpacking canteen.
Those of you familiar with my previous aluminum bottle Instructables:
ROLLED RIM METAL TUMBLER
http://www.instructables.com/id/Aluminum-Bottle-Tumbler-Cup-Cook-Pot/
ALUMINUM BOTTLE LIGHTWEIGHT ALCOHOL STOVE
http://www.instructables.com/id/Aluminum-Bottle-Alcohol-Stove/
will recognize the water canteen shown below as a re-purposed aluminum beer bottle. Here, I have added a painted surface treatment to turn it into a proper looking water bottle. More on that in steps 13, 14, 15.
Step 1Getting Started
Getting Started
Cord size is important. Select a small medium weight cord like the one shown here. It is a general purpose camp cord sold at most sporting goods stores. (shoelaces might also work)
Do not use a heavy cord or rope because the larger diameter will not tuck under the relatively small lip at the top of the bottleneck and the bottle will fall out.
Also, the smaller cord cinches tight on itself and will not loosen accidentally.
64 comments
1-40 of 64next »
Nov 13, 2011. 4:45 PMbmelton1 says:
I actually laughed when I started tightening mine. Not because it was funny but in disbelief that I did it right!
Nov 6, 2011. 8:24 PMnutsandbolts_64 says:
Tip: put up a video, it makes everything easier than it already is ;)
Sep 29, 2011. 2:37 PMCaseBoy says:
can this be removed without uniting the knot
Aug 18, 2011. 6:35 PMJMRaphael says:
I've been to about a half-dozen other sources and is this is the first one that explained the knot in a clear, easy-to-follow fashion. Most sources fail around the point where you begin crossing loops over, but you did an excellent job of explaining those steps. Kudos to you; keep up the good work.
Aug 15, 2011. 9:10 PMMSCRCEI7 says:
I liked the color coded tape to help explain. Kudos.
Feb 26, 2011. 6:37 AMwibown says:
Thank you so much. Your directions are VERY clear and easy to follow. I really enjoyed learning how to tie this knot.
Sep 24, 2009. 12:07 PMCovo says:
I grew up calling this knot the Anga-gah-sec-agnute (sp?)...not sure if my Grandfather made the name up or it was the scandinavian name. He also said that the vikings would use this to tie a line to their "spirits" and other beverages, then throw them overboard to keep them cold. Anyone ever hear this or was I the victim of childhood gullibility? I currently use it on my key chain.
Jan 31, 2011. 5:49 AMgeoslim13 says:
was he a sailor, because this knot was most common on sail boats and sailors make words like that up.
Jan 24, 2011. 12:47 AMybunnygurl says:
I don't know the name but I have heard this story too, when I learned how to make almost the same knot... this is easier then the way I was tough so I'm using this one now.
Sep 20, 2010. 5:53 PMWayfinderAli says:
I haven't heard of this, but, if Vikings kept their water/spirits in glass or ceramic bottles it would be VERY possible that they did this. I'm not sure if it would work using some sort of container made from an animal bladder. I do this (this being hang my water bottle over board) when I'm out on an expedition kayaking trip. I lead 5 day kayaking trips along the North Carolina outer banks. To keep it cool I'll often use a carabiner to lash it to my deck rigging and drag it with me. The sound isn't that much cooler than the air, but if I store my water in my cockpit with me, it still gets warmer than the water in the sound. On the deck of the kayak it'll get as hot as bath water. Out on the ocean, where the Vikings would have been sailing, the ocean water would be pretty cold even on hot days and would keep tasty beverages pretty cool.
Jan 16, 2011. 9:24 AMjarofol says:
I must commend you on this instructable on what now seems such a simple not to tie, NEVER have i seen such clear and easy to understand instructions on any knot before.
Sep 20, 2010. 6:54 PMWayfinderAli says:
I love the cork stopper. How did you cut a hole in the synthetic cork so that it looks so nice and clean? I was thinking about drilling a hole but that seems like it would look ragged. Also, where did you find a cork that was plain white? All the synthetic corks I see from wine bottles have something printed on them like grapes or something.
Oct 3, 2009. 10:47 PMKryptonite says:
Hey great Instructable, I got a new bottle from an expo that I went to on the weekend and it was great for holding it. Do you think you could post an Instructable about different trussing techniques? Any way, thanks. Favourited, and here are some pictures.
Jun 29, 2010. 5:34 PMmysss says:
Indeed. I haven't seen anything like that, even though I was already familiar with this knot!
Jul 11, 2010. 8:56 PMKryptonite says:
Yeah it looks awesome.
Jun 14, 2010. 6:55 PMgolfer12345 says:
guess what i just figured out you can use a neck lanyard and it makes a great handle. the second picture is the clasp on my neck lanyard
Jun 5, 2010. 7:33 PMskaterqwertyuiop says:
I always carry my load-bearing Carabiner with me (on my beltloop). If I flip it so the skinny side is down, I can insert a bottle and slide it down, it locks in place because it is a perfect fit. That's how I carry my water bottles with me :P
Jan 16, 2010. 2:04 PMtulekah says:
i've been using jug-slings for years (ashley) but it never occured to me to string a cork on the loop.  brilliant!
Nov 23, 2009. 1:07 PMVikkiHowells01 says:
Great instructable - thanks!
There is a REALLY neat way of tying a jug knot. Take a look at the link below. Don't worry about the dialoge - actions speak louder than words.
http://www.youtube.com/watch?v=lqdKyhY9X30&feature=related
Nov 10, 2009. 3:29 PMspacedog73 says:
I just did one of these for a bluegrass fest I just went to.  I didn't have an aluminum bottle so I used an big old Chimay bottle and a natural cork.  Very cool.  I cut up some old can coozies to keep the bottle cold and protected.
Oct 28, 2009. 9:04 PMscottm_113 says:
This has got to be one of the BEST Instructables that I've seen yet. It's a simple project and Very well laid out...and Useful too! I tip my hat to you!
Oct 17, 2009. 4:29 AMstatic says:
 Great instructable with a useful skill to learn. Thanks  for posting.
Oct 16, 2009. 11:50 PMt-b0ne says:
i made an awesome water bottle thanks to you!  i got a sweet half liter glass bottle from the army surplus store (the type made for corks), and managed to secure a champagne cork on the knot!  thanks a lot, i have the coolest water bottle ever :)  <3
Sep 27, 2009. 4:16 AMgHjM3W5T20YCS4e30 says:
more photos of this version this is perfect for 550 paracord
Sep 27, 2009. 8:10 AMrtadlock says:
Here is the complete set of pictures I took. It includes close ups of all the knots - <a rel="nofollow" href="http://www.flickr.com/photos/rtadlock/tags/jugknot/show/">http://www.flickr.com/photos/rtadlock/tags/jugknot/show/</a><br/>
Sep 26, 2009. 3:56 PMrtadlock says:
Awesome instructable and thanks for reminding me I like to tie knots. Here is my finished product (complete with a few more knots): http://www.flickr.com/photos/rtadlock/3957170956/
Sep 25, 2009. 11:18 AMseaworthy says:
Approximately how long a cord should I start out with to get a result like that shown in Step 1? Thanks.
Sep 25, 2009. 5:17 AMkleinschmidt says:
Very nicely done. Two things though: 1. For a first timer, it would be helpful to know how long a piece of cord to use. You say to put the bight in the middle of the cord, but a 24" cord or a 24' cord? 2. It would be nice if the first picture had some size reference. A pencil or a hand or something. The mat and the arrows make it very clear what steps, but they do not give much sense of scale. Thanks for a great set of directions!
Sep 25, 2009. 4:12 PMangelmi says:
Well done. Your use of graphics and color was very helpful. I was making the knot in no time. Thanks.
Sep 25, 2009. 2:33 PMaphesia says:
great instructable. and it focuses on the repurposing of otherwise useless refuse. 54 points!
Sep 25, 2009. 1:48 PMMother Natures Son says:
This is killer. I'd love to know how you did the one in the last step, but I imagine that'd be kind of in-depth.
Sep 25, 2009. 12:15 AMforoncethen says:
This is quite possibly one of the slickest knots I have ever seen. I am very much impressed by both it, and the quality of this instructable. Well done.
Sep 24, 2009. 7:25 PMmarcintosh says:
Well yes this is a great instructable. It tells me how to mod some great stuff and It's all green and all that I expected BUT what really pulled me in is the clarity of images and the method you used to illustrate the knot tying.
I've taught kids and adults to tie knots for various reasons in various groups. Your visuals beat any book or pamphlet or flashcards I have ever used hands down. Thanks for your work.
Sep 24, 2009. 1:39 PMSewicked says:
I'm a little confused *hanging head*. The center of this melange is/will the knot, correct? So I ~lift it up, to move the 'yellow' from right to left?
1-40 of 64next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
609
Author:hpstoutharrow
