loading
Step 14: Tethered Cork Stopper
Use a wine bottle man made Cork as a stopper for your aluminum water bottle.
Note: Use a cork that was removed from the wine bottle without the corkscrew penetrating through the bottom end of the cork. (A hole all the way through the cork will cause it to leak.) Use the unpierced end of the cork inside the water bottle.
Drill a hole through the sides of the Cork. Thread the cord through the hole to the center of the cord. Use the cork as the main Bight. and tie the Jug knot as shown in the beginning steps.
Now the cork is tethered to the bottle and will not get lost or fall on the ground.
A Carabiner clip passes through the other cord end to attache the water bottle to you belt or pack.
<p>Try this simple technique. Much more easier to understand and learn</p><p>https://www.youtube.com/watch?v=HtSCIlS9MbM</p>
<p>I got so close, but couldn't remember steps 8 and 9. Thanks to your color-coded images, I was able to put handles on these jugs for our outdoor workshop. ^_^</p><p>(Photo credit to Laura.)</p>
Done.
<p>BSA Troop 45 (Oxford, MS) uses the enclosed two methods to secure a water bottle for hiking. Both methods use 6 feet of 1/8 inch diameter rope. (The length of 6 feet keeps the rope very usable and serviable. Also for knot tying practice the rope needs to be at least 6 feet, any length less makes it harder to understand to knots use).</p><p>1) Ancient Egyptian Jug Knot- A bead has been added for decoration (after the knot is made and still in a loose condition, with one of the loose ends, thread the bead and slide it in position- up around between and down to the enclosed loop) . The carring strap may be adjusted by the double fishermans knot (or inside figure eight).</p><p>2) Bottle Sling- This is a teaching tool for knot tying and learning each knots use.</p><p>Yours In scouting,</p><p>Steve Mauldin</p><p>smmauldin@bellsouth.net</p>
<p>Thank you so much for the super clear tutorial :) I received a solar lantern cap a while back, but haven't really tried to use it for camping with my Nalgene because I didn't have a good way to secure it to the bottle (and being so used to the attached cap, I figured I would surely drop the thing at an inconvenient time, with it rolling over a cliff or something equally dramatic--that's just the way my luck typically works). This, however, worked on the first try and looks great :D Thanks!</p>
<p>can you please do a tutorial on trussing like that bottom picture i have several bottles that don't have a lip at the top</p>
I had the same reaction as bmelton1, to be honest, this is the first paracord instructable I've ever tried, and it came out perfect. Now I've got a water bottle to attach to my camp/survival pack.
It looks like its just a Turks head with a loop in one end
I commend you on the clear, easy-to-follow, precise instructions. The idea of marking the bights made this a very simple knot to tie. If there were any ratings that went above 5, no matter how much, I would give them to you. Keep up the great work. To sum up what I've written, EXCELLENT JOB!!!!!
I grew up calling this knot the Anga-gah-sec-agnute (sp?)...not sure if my Grandfather made the name up or it was the scandinavian name. He also said that the vikings would use this to tie a line to their "spirits" and other beverages, then throw them overboard to keep them cold. Anyone ever hear this or was I the victim of childhood gullibility? I currently use it on my key chain.
I haven't heard of this, but, if Vikings kept their water/spirits in glass or ceramic bottles it would be VERY possible that they did this. I'm not sure if it would work using some sort of container made from an animal bladder. I do this (this being hang my water bottle over board) when I'm out on an expedition kayaking trip. I lead 5 day kayaking trips along the North Carolina outer banks. To keep it cool I'll often use a carabiner to lash it to my deck rigging and drag it with me. The sound isn't that much cooler than the air, but if I store my water in my cockpit with me, it still gets warmer than the water in the sound. On the deck of the kayak it'll get as hot as bath water. Out on the ocean, where the Vikings would have been sailing, the ocean water would be pretty cold even on hot days and would keep tasty beverages pretty cool.
Oft times, in days of yore, containers made of animal bladders were covered with a natural waterproofing material such as insect shellac or some sort of tree sap or gum. This kept bottles from leaking. It didn't keep them from aquiering,(sp), an off taste. The coating also made them hard and they could be hung with out distorting.
was he a sailor, because this knot was most common on sail boats and sailors make words like that up.
I don't know the name but I have heard this story too, when I learned how to make almost the same knot... this is easier then the way I was tough so I'm using this one now.
I actually laughed when I started tightening mine. Not because it was funny but in disbelief that I did it right!<br>
Tip: put up a video, it makes everything easier than it already is ;)
can this be removed without uniting the knot
Yes, the knot can be loosened without untying it.
I've been to about a half-dozen other sources and is this is the first one that explained the knot in a clear, easy-to-follow fashion. Most sources fail around the point where you begin crossing loops over, but you did an excellent job of explaining those steps. Kudos to you; keep up the good work.
I liked the color coded tape to help explain. Kudos.
Thank you so much. Your directions are VERY clear and easy to follow. I really enjoyed learning how to tie this knot.
I must commend you on this instructable on what now seems such a simple not to tie, NEVER have i seen such clear and easy to understand instructions on any knot before.
I love the cork stopper. How did you cut a hole in the synthetic cork so that it looks so nice and clean? I was thinking about drilling a hole but that seems like it would look ragged. Also, where did you find a cork that was plain white? All the synthetic corks I see from wine bottles have something printed on them like grapes or something. <br>
The cork does have printing, just not on the side shown. At the risk of plugging a product...Barefoot Wines has a cork with a footprint on it. (Very appropriate for a hiker's water bottle.)<br><br>As far as the hole in the cork, a drill works nicely. The cork has a tendency to close-up when the bit is removed so use one larger than you would think.
Hey great Instructable, I got a new bottle from an expo that I went to on the weekend and it was great for holding it. Do you think you could post an Instructable about different trussing techniques? Any way, thanks. Favourited, and here are some pictures.
Indeed. I haven't seen anything like that, even though I was already familiar with this knot!
Yeah it looks awesome.
guess what i just figured out you can use a neck lanyard and it makes a great handle. the second picture is the clasp on my neck lanyard
Excellent
I always carry my load-bearing Carabiner with me (on my beltloop). If I flip it so the skinny side is down, I can insert a bottle and slide it down, it locks in place because it is a perfect fit. That's how I carry my water bottles with me :P
i've been using jug-slings for years (ashley) but it never occured to me to string a cork on the loop.&nbsp; brilliant!
Great instructable - thanks!<br /> <br /> There is a REALLY&nbsp;neat way of tying a jug knot. Take a look at the link below. Don't worry about the&nbsp;dialoge - actions speak louder than words.<br /> <br /> <a href="http://www.youtube.com/watch?v=lqdKyhY9X30&amp;feature=related" rel="nofollow">http://www.youtube.com/watch?v=lqdKyhY9X30&amp;feature=related</a>
I just did one of these for a bluegrass fest I just went to. &nbsp;I didn't have an aluminum bottle so I used an big old Chimay bottle and a natural cork.&nbsp; Very cool.&nbsp; I cut up some old can coozies to keep the bottle cold and protected.&nbsp;
This has got to be one of the BEST Instructables that I've seen yet. It's a simple project and Very well laid out...and Useful too! I tip my hat to you!
&nbsp;Great instructable with a useful skill to learn. Thanks &nbsp;for posting.
i made an awesome water bottle thanks to you!&nbsp; i got a sweet half liter glass bottle from the army surplus store (the type made for corks), and managed to secure a champagne cork on the knot!&nbsp; thanks a lot, i have the coolest water bottle ever :)&nbsp; &lt;3<br />
more photos of this version this is perfect for 550 paracord
Here is the complete set of pictures I took. It includes close ups of all the knots - &lt;a rel=&quot;nofollow&quot; href=&quot;http://www.flickr.com/photos/rtadlock/tags/jugknot/show/&quot;&gt;http://www.flickr.com/photos/rtadlock/tags/jugknot/show/&lt;/a&gt;&lt;br/&gt;<br/>
Awesome instructable and thanks for reminding me I like to tie knots. Here is my finished product (complete with a few more knots): <a rel="nofollow" href="http://www.flickr.com/photos/rtadlock/3957170956/">http://www.flickr.com/photos/rtadlock/3957170956/</a><br/>
Approximately how long a cord should I start out with to get a result like that shown in Step 1? Thanks.
The cord length shown in the photo in step 1 is 36 inches.
Very nicely done. Two things though: 1. For a first timer, it would be helpful to know how long a piece of cord to use. You say to put the bight in the middle of the cord, but a 24" cord or a 24' cord? 2. It would be nice if the first picture had some size reference. A pencil or a hand or something. The mat and the arrows make it very clear what steps, but they do not give much sense of scale. Thanks for a great set of directions!
24 inches for a <strong>Water Bottle</strong>......24 feet for a <strong>Water Tower </strong> It all depends on what you are tying around :)<br/><br/>If you look closely in step 9 you can see my assistant helping with cord he may help with the scale...or k not.<br/>
Well done. Your use of graphics and color was very helpful. I was making the knot in no time. Thanks.
great instructable. and it focuses on the repurposing of otherwise useless refuse. 54 points!
This is killer. I'd love to know how you did the one in the last step, but I imagine that'd be kind of in-depth.
This is quite possibly one of the slickest knots I have ever seen. I am very much impressed by both it, and the quality of this instructable. Well done.
Well yes this is a great instructable. It tells me how to mod some great stuff and It's all green and all that I expected BUT what really pulled me in is the clarity of images and the method you used to illustrate the knot tying.<br/>I've taught kids and adults to tie knots for various reasons in various groups. Your visuals beat any book or pamphlet or flashcards I have ever used <strong>hands down.</strong> Thanks for your work.<br/>
Thanks for the compliment. I tried different size cord and rope for the demo but found them difficult to control and look consistent for the photo shoot. Finally decided to use wire. 14 gauge automotive wiring held its shape nicely. Added the directional arrows to the photos with MS Powerpoint.
I'm a little confused *hanging head*. The center of this melange is/will the knot, correct? So I ~lift it up, to move the 'yellow' from right to left?
About This Instructable
282,600views
785favorites
License:
More by hpstoutharrow:New Year's Tree Print Waterproof Plastic Maps Volcano Picnic Plate
Add instructable to:
