Carter's Lasercut Tank - KV-1 (motorizable)
3,432
51
6
Published
Introduction: Carter's Lasercut Tank - KV-1 (motorizable)
About: I love lasercut. I love tanks. Let's conciliate dis.
Here is the tutorial to assemble the KV-1 model i made. the final model is about ~1/18 scale (about 37 cm long).
You will need :
  • 20x 40mm Ø3mm screws with 2 nuts per screw (40 bolts then)
  • 6x 20mm Ø3mm screws with one nut per screw (only 2 screws can be enough)
  • 2x Ø3mm 50-60mm long rods
The tank is available here : https://www.thingiverse.com/thing:2449310
A hollow space has been made at the rear of the tank to provide some motors for the wheel-drive. However, the space is a bit too small...
Step 1: The Frame
Begin with the internal frame. i use some triangle shaped scrap to wedge the screw supports (see photos). I put the sheets all around the frame then.
Step 2: The Backside Curves
Make sure to not have a final space between the two frames.
Step 3: The Sides
We will fix them later.
Step 4: The Rear Trapdoor
Step 5: The Turret
I give you the choice to put some decals on the sides, or not.
Also, ou can choose the gun position on the back side between, on the left, the middle, or no gun at all. The real tank had the gun on the middle.
Step 6: The Details
Step 7: The Wheels
Use the two rods for the drive wheels.
Step 8: The Tracks
This part can be long. Do not forget to make two tracks of course ;)
Step 9: The Chests
Fix it to the fenders with some double sided tape instead of wood glue, it will be easier if you want to remove them.
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    6 Comments
    Excellent work!
    Hope to see more masterpiece like this!
    What material and what thickness are made by machine? I think the material thickness of 2.25 mm or am I wrong? Different parts of the machine are made of material the same thickness?
    excellent piece of art buddy , specially the moving tracks , how strong they are ? do you have idea about how to make the robust and reliable metal or non metal tracks ?is it possible, to mount DC motor and Arduino shield to move these device ?
    Thanks
    Those tank treads are awesome! Are you going to try and hook up a motor?
    it will be a bit difficult the space is not large enough :/
