3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Carve A Traditional Maori Hook Necklace From Bone
Make sure to check out my blog!
 This is a Maori hook I carved from cow bone. Carving bone is a pretty slow process...I carved this over the course of two days.
Carving a personal 'totem' like this is kind of like a journey. It's a very personal experience...
After all the time and hard work invested, and holding something so pure and beautiful... something that you carved, is an experience everyone should have (but so few do).
Before you carve your Hook, I recommend reading up on Maori culture. It's very fascinating and helps give you the inspiration you'll need for the 'journey' ahead.
Step 1Pattern
Pattern
 Drawing a Maori hook is INCREDIBLY difficult. I recommend Googling "Maori Hook" and tracing a design you like. Cut out the traced hook, and transfer it to the bone blank (in pencil).
When picking a cow bone to carve, make sure it is white as paper. If it is in any way translucent or yellow, it contains grease. Grease will wreck your carving! Do not carve greasy bone!
You can get bone from PetsMart. It's in the form of cleaned bone dog toys (the ones made of REAL cow bone). You may even have a bone in your yard, dropped by some else's dog (or your own!).
From here on out, safety glasses are a must!
198 comments
1-40 of 198next »
Mar 16, 2012. 3:16 AMcykovisuals says:
Do not inhale bone dust, it is bad for you. If using a rotary tool, always wear eye protection AND a filter mask, you can get them from the hardware store for a few bucks.
Mar 1, 2012. 6:58 AMbuilderv says:
this is cool i will do this project soon good instructions good job
Feb 6, 2012. 11:44 AMDutch56 says:
I just stumbled upon this 'ible. When I saw your first photo I thought you used jade and then I noticed the section of bone that you drew your design on.
Having been a butcher in the past, another fairly flat bone to use would be the shoulder blade bone that is found in chuck roasts or 7-bone roast or you can use the bones from beef short ribs-most measure about 1 1/2 inch X 1 1/2 inch and are fairly flat with just a slight curve.
Now I just have to clean my work shop so I can get access to my band saw and drill press. Bring on dem bones
Aug 7, 2011. 2:54 PMMistwalker says:
I've always wanted to make one of these, and finally got a rotary tool and bits, and decided to get it done. I looked over this instructable, though I don't have the same tools, so much of it didn't apply. Took me three days or so to do this one. It's made out of a cow femur I purchased at petsmart.
I didn't use any particular design, though it was influenced by ones I've seen. I sketched it out myself. Actually, over and over again, as I worked the bone down. It changed a bit as I worked with the bone. Turned out well, I think.
Jan 15, 2012. 7:45 PMgreeneyedJill says:
Beautiful! You did awesome.
Aug 7, 2011. 8:52 PMMistwalker says:
I will indeed carve more. I have plenty of femur left. I was intending to string it with hemp cord I have, but I couldn't find it. So, I looked up a video on how to make rope, and I went and cut some willow branches, and used the bark to twist my own cord for it. It turned out pretty well, considering I've never made rope before. I'm quite proud of this, considering every part of it is something I made myself.
Aug 10, 2011. 5:18 PMMistwalker says:
I carved another one today. My rotary tool crapped out at the end of it, but it's OK, it's still in warranty. I think I might make more of these, and sell them online someplace. The design isn't based on anything in particular. I just sketched out some designs on paper and picked the one I liked best.
Jan 2, 2012. 5:24 AMnikora says:
man i am really impressed with your work, keep it up
Aug 11, 2011. 5:21 PMMistwalker says:
Well, no, it didn't crap out entirely. It was just making a horrible grinding noise and wouldn't maintain speed. I think the bone dust wore out the motor bushing. It's still in warranty, though. I'm taking it over to the Black & Decker service center tomorrow and they'll mail me a brand new one. I haven't heard of any other similar problems with this particular rotary tool, so I think I just got a dud. All the same, I'm going to buy some filter material and wrap it around the intakes (checking to make sure it doesn't overheat), and I also plan on getting a flex shaft attachment, so I can hang the tool up high away from most of the dust. I'll be back to carving bone in about a week's time.
Aug 30, 2011. 10:59 PMMistwalker says:
Got my replacement rotary tool, got a flex shaft attachment, and started carving again. This one isn't quite finished, but it's looking pretty good. Thought I'd share it.
This time, it isn't a hook, though the shape is similar. It's a representation of a Maori spiritual figure, called the Manaia, who was meant to have the head of a bird, the body of a human, and the tail of a fish or a whale, though representations differ quite a bit. The bird head represented the sky, the human body the earth, and the tail the oceans. The Manaia was considered a guardian of sorts, and a messenger to the spirit world. It's a fairly common Maori carving.
I think I might do a Maori Tiki next, though I'm not sure.
Sep 5, 2011. 6:21 AMMistwalker says:
I've carved a couple more since then, one is a Maori twist style pendant, and the other isn't terribly related to anything Maori, though it is informed somewhat by the style. It was just something I sketched that I liked the idea of. I've been trying each time I carve to do something I haven't done before. I'm getting much quicker at it. Though, I'd be quicker still if I didn't have to cut out the initial shape with cut off discs. It's slow, makes a lot of bone dust, and the discs shatter and the pieces go flying in random directions.
I need to learn how to tie Maori knots, too, and also learn a proper polishing technique that works for complex surfaces. At some point I want to get a better hanging flex shaft tool, like the sort jewelers use.
You should post more of your carvings. If you want, I could show you some sketches of designs I've done. Might give you a few ideas.
Mar 22, 2012. 12:44 PMbrianfss says:
You need to do your own instructable. Your work is excellant. Love the designs. can you give us an idea of the dimensions?
Nov 6, 2011. 2:15 PMTinkering_Pirate says:
Both of your carvings are beautiful! Thanks for the inspiration!
Jan 15, 2012. 7:44 PMgreeneyedJill says:
I love the way your hook turned out! Can I do the same thing with wood, using the same tools? I would prefer wood over bone. Thanks
Maori carvers are able to use or wear their work but the rule is that you must always give your first away. awesome carvings by the way. going to make one for my daughter soon of a mania.
Dec 25, 2011. 11:10 AManibioman says:
this is really cool i think ill make one for my brother when his birthday comes around (april) that is a really nice shine on yours.
Nov 20, 2011. 12:05 AMb_l_87 says:
i made this for a friend of mine.
Nov 15, 2011. 1:38 PMrachelxie says:
Very beautiful ! you need make this type product ,you can find me do.
We can make the big auto mould,automobile mold,outlet mold,bumper mold and plating plastic part, prototype mold, silicone mold, medical mold, office appliance, home appliance
web:www.ft-mould.com
rachelxie6789@gmail.com
Nov 11, 2011. 4:36 AMnerd12 says:
This is good but do you really want to put a ornament which was worn by blood thirsty, flesh eating cannibal on your skin. it might not be a tooth but it still symbolizes them.
Nov 11, 2011. 5:03 PMnerd12 says:
???? do you mean you made 42 pendants? you must seriously like them. the shaolin monk still beat them.
Ps- that was a reference to discovery science channel deadliest warrior.
Jul 11, 2011. 11:15 PMCosmicBrambleclaw says:
Sweet tutorial :3 I think I might make a Manaia necklace with this picture http://i2.squidoocdn.com/resize/squidoo_images/-1/lens10713211_1272378728Maori-Manaia.jpg then maybe a hook after that :3
Jul 11, 2011. 8:31 AMdoomsdayltd says:
personally i love maori's, but people need to look into what they are and there history. There's many different maori's all made of bone, jade, or exotic Hawaiian hardwoods. Now this necklace that you made is representation of an old new zealand tale of a man who caught the largest fish in the world with a bone and woven fish hook. Because of this tale the maori fish hook presents prosperity, fertility, and safe passage over water. Lastly the maori is to be crafted by someone and then given to someone for a special meaning or occasion, meaning they must not be worn by the craftier.
Jun 29, 2011. 12:39 PMTwistedJack says:
Were do you get your bones? I'm having trouble finding the right kinds and also most of the ones I do find have meat on them.
Oct 13, 2010. 2:16 PMsonofspikerr says:
is it possible to make this out of wood? Because i dont have access to many cow bones... I tried in industrial tech, but the bandsaw was dull and wouldnt cut right
Jun 24, 2011. 4:24 PMThe Metal One says:
not in my opinion, ive done a lot of carving, and even when i used superhard woods like black walnut and hickory the hook split in some way, tried 4-5 times before chisels and files were flying all over the shop.
Jun 25, 2011. 1:02 PMsonofspikerr says:
haha ok :)
Oct 14, 2010. 5:54 AMsonofspikerr says:
thanks! i'll keep trying to get a bone ecause these are amazing
Jun 14, 2011. 8:00 PMTape-structable says:
My attempt. It was initially very "meaty" as in there was more "bone" on it than what you see now. And I put bone in quotes because it isn't bone, but a plastic poker chip, with the word 'dealer' on it. Next attempt will hopefully be with real bone, or at least a nice wood. Thank you for your inspiration!
Tools used were:
Utility saw
files of various sizes
craft knives (x-acto)
Jun 24, 2011. 4:05 PMThe Metal One says:
DONT USE WOOD!!!!! it split apart everytime i tried to carve the contours, like 5-6 times before i rage quit and threw tools all over the shop.
Jun 24, 2011. 4:26 PMThe Metal One says:
try doing a maori "tooth" design, less challenging but with the same amount of satisfaction. :)
Mar 25, 2011. 3:19 AMSkwaab says:
This was great, my first was terrible, but i'm gonna have to have another go.
anyone else think the burnt bone smelt like cool origanal doritos? ;)
May 8, 2011. 3:45 AMjamiec53 says:
Are you supposed to sniff it...
1-40 of 198next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
315
Author:nepheron(MakerWeekend)
I have an awesome blog @ www.makerweekend.com Im Calvin Drews, and I love to learn, experiment, invent, create, repair, and generally just do things myself. A sort of modern jack of all trades, mast...
more »
