Carvers Lap Table
Introduction: Carvers Lap Table
If your like me you don't have a heated work shop to carve. Well, with this simple lap table you can enjoy carving in the comfort of your home while basking in the warm glow of your TV without wood chips cascading onto the floor.
I've seen different ones online. You can make them as fancy as you want but this is how I built mine. You can buy them but.....ya know.
Step 1: Tools and Materials
Basically you need:
1 1/2 inch piece of plywood 24"X24"
About 9 feet of pine 1/2 x 3/4 stripping
Wood screws
Wood glue
A saw
Scroll saw
A square
Drill and bits
Spring clamps
Tape measure
You can change the size depending on how big you want it.
Step 2: The Layout
Pretty simple. The end of the table that goes towards your body has a curve and a lip to keep stuff from rolling away or falling off. The top has an area where you can put your knives and other tools.
Step 3: Cutting the Plywood
I bought a 24 x 24 inch piece from the store. The only thing I had to cut was the curve at the bottom end.
I did this by using a pliable piece of wood and tracing the curve.
Trace the curve leaving two inches on both sides. If you're fancy use math. You can also make a template out of cardboard.
Once you have the curve plotted out cut it with a scroll saw.
Step 4: Cutting the Sides, Front and Middle Piece
This part is EASY!!!!!
From the pine strip cut:
2 pieces 23" long (sides)
1 piece 24" long (front)
1 piece 221/2 " long (middle)
Step 5: Cutting the Curved Lip for the Bottom
This part can be tricky.
Cut a piece 221/2" long.
Take that piece and use your already cut curve in the plywood and trace the curve onto the strip.
I cut mine with a table top jig saw.
If you traced correctly it should match pretty well.
Step 6: Drilling the Holes
Through the back pre drill the holes with a 1/16th bit and then pre sink them. This way the screw heads will be below the surface of the tray making it smooth.
Step 7: Assembly!!!!!!
Start with the front piece. Apply a bead of wood glue. Line it up with the plywood and then use clamps to hold it in place. Go ahead and begin to apply the screws. Repeat for the sides, middle and bottom lip.
If the lip doesn't match up perfectly, you can always trim it or correct the problem when you sand. Take your time!!!
Step 8: More Drilling, More Screwing
Repeat the drilling steps but this time secure the sides to the middle, top and bottom lip pieces.
Step 9: A Pencil Holder
Just drill a couple holes in the middle piece big enough for your pencils!!!
Step 10: Sand It!!!!
You want to sand the whole thing. Make sure it's smooth, especially the back because it will be on your lap and you don't want it to snag clothing. Round all the edges and corners with the sander, this way it won't damage you or your furniture.
Step 11: Apply the Polyurethane
Blow all the dust off and then wipe it down with a damp rag. I used quick drying poly. Apply enough coats until your happy with the surface. Allow it to dry between coats. If you want it super glossy, lightly sand in between coats.
Step 12: Go Carve!!!
Grab your tray, wood and tools, turn on your favorite show (Real Housewives of Orange County) and create a masterpiece!!!
FYI, not my favorite show.....
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    The addition of a bean bag to the underside so it sits firmly might be a useful addition. And I'm sure it will be useful for other craft hobbies to.
    I've been doing a lot of carving lately (out in my cold garage), and many times I've wanted to bring the piece inside to work on. But I never did because I didn't want to clean up all the chips...!
    This is a great idea!
