Introduction: Casserole Carrier
Picture of Casserole Carrier
This Casserole Carrier will keep your dish safe and hand heat free. Food will stay warm just a little longer with the insolation provided. This one is a gift and I'm filling it with all the fixings for my favorite hot dip.
this project is based off the size of your particular casserole dish. The measurements will need to be filled in accordingly.  These are guide lines intended to help you work through figuring out your own dimentions. they are by no means exact.
Step 1: What You Will Need
Picture of What You Will Need
Main fabric  less than 1 yard
Lining less than a yard
Isolated batting
Thread
Casserole dish with lid
Zipper (2 x width )+length + 3"
or zipper off the roll works well, less than a yard needed.
webbing  yardage needed is (Width x 6") + (depth x 4") + 2" for join *a little extra is good.
Marking tool
Ruler
Sewing machine
Iron
Pins
Scissors
Step 2: Getting Started
Picture of Getting Started
You will need to take detailed measurements of the dish. Using the larges dimensions  determine  length, width, and depth of your dish with the lid on.
Cut 2 rectangles from main fabric using the measurements  length + 2" by the width + 2".
Cut 2 long and thin rectangles the length of zipper +2  by depth + 1" from main fabric.
(There is a bit of wiggle room here. its very hard to get an exact on this before you sew.
Cut these 2 pieces next to each other so the repeat on the pattern looks better. )
Cut 1 rectangle  length + 4" by the depth + 1 1/2" . You can cut a lining piece this same size at the same time.
Step 3: Cut Lining and Batting
Picture of Cut Lining and Batting
ruff cut the lining  and the batting 1/2" or larger  all around
Step 4: Assembling
Picture of Assembling
Layer the lining right side out then batting then fabric face up. Pin in place
Step 5: Baste
Picture of Baste
Stitch the layers together. You can use a regular long baste stitch or zig zag stitched. be sure to stay closes to the edge with stitching.
Trim batting and lining to match face fabric . this is much easier then keeping the layers straight and from shifting if all 3 were the same size.
Step 6: Zipper Time
Picture of Zipper Time
Take the 2 long this rectangles and fold them in half log ways. you can press them if needed.
Baste close to the raw edge on the long side.
Pin fold to the zipper and one on the other side of the zipper. Give yourself some room. No need to be very close to the zipper here.  Check the print to see if the design is lined up.
Stitch very evenly along the fold, then repeat for other side of the zipper.
Use a zipper foot if you need to.
Step 7: Baste Again
Picture of Baste Again
Take the small rectangle and baste it to the matching lining, right sides out for both fabrics.
Step 8: Attach to the Zipper Panel
Picture of Attach to the Zipper Panel
Take the small rectangle and sew right sides together to the zipper panel as shown with 1/2" seam allowance
Step 9: Zipper Panel Attached to Top.
Picture of Zipper Panel Attached to Top.
with right sides together pin zipper panel along the short side of the large batted rectangle otherwise known as the top of the carrier.
the seam you just made will be even with the long side of the rectangle. Sew in place using a 1/2" seam allowance. stop stitching and back-tack 1/2" from the end of the side indicated by the purple dot.
Step 10: Snip
Picture of Snip
Snip up to but not through the stitching.
Step 11: Turn the Corner
Picture of Turn the Corner
the snip you just made will help you to make a clean turn. pin the zipper panel down the next side. Start sewing at 1/2"  down and in, or where you just stopped sewing previously. You will repeat the process to round the next corner as well.
Step 12: Making the Join
Picture of Making the Join
stop  sewing 2" before the 3rd corner, indicated by the pin.
Take the unattached non-zippered part for the panel and pin it along the remaining long side towards the corner. pin along the short side at the corner. once you have determined where they should meet sew them together along this short side. Trim off any excess fabric  to a 1/2" then you can continue to attach the zipper panel to the top.
Step 13: Time to Flip Over to the Other Side
Picture of Time to Flip Over to the Other Side
staring along the non-zipper section work the same as previously. stopping the stitching 1/2" in from each corner and using a 1/2" seam allowance. clip corners and continue to the other side turning your work. Don't forget to open your zipper up before you finish.
Step 14: Clean Up the Mess
Picture of Clean Up the Mess
Zig zag stitch over the edges of the seams to minimize the fraying and increase the longevity of your project.
Step 15: Attaching the Webbing
Picture of Attaching the Webbing
Fold webbing in half and sew with 1" seam. mark with a pin the half way point.
Press open seam and place raw edges face down as shown. Arrange in a comfortable balanced position for your dish. the seam and the half way mark shout be parallel. I put them in the center. Once you are happy with the placement open the carrier and stitch the webbing down along each side only on the bottom of the carrier.
Step 16: Wide Webbing Fix
Picture of Wide Webbing Fix
The webbing I used was very wide so I had to stitch the folded section together for a more comfortable handle.
Step 17: Finished
Picture of Finished
This is the finished Carrier.
karalalala (author)2014-01-07
Congrats! Totally voted for you, and if I had a sewing machine or any ability at all with a needle and thread I would have my own casserole carrier right now. Great idea!
RebekahP (author)karalalala2014-01-07
Thanks for the vote! We all have our own talents, I look at the electronic stuff and get that same feeling.
HollyMann (author)2013-12-09
cute!
Penolopy Bulnick (author)2013-12-09
Oooh, I've been needing to make one of these!
About This Instructable
6,350views
114favorites
License:
Bio: Can't sit still. If my hands are not busy I'm not happy. Love trying new foods.
More by RebekahP:Summer Knit Dress in 3 sizesAssassin's Creed Inspired HoodWallet Sewing Pattern and Tutorial
Add instructable to:
