I don't have any photos of the making of it but it's fairly simple and I will attempt to explain the steps.
All the items you need to make it are easly available.
I've seen this instructable after building mine
http://www.instructables.com/id/Retro-tribute-CaSsette-TaPes-LamP-with-Joystick-/?ALLSTEPS
Looks cool too
Step 1 Here's what you will need.
• IKEA: HEMMA, Table lamp base, black. Article Number : 501.495.17 (Make sure it's the 13cm width/length base not the 15cm one they also have available)
• Low energy bulb (or one that produces less heat than a normal clear bulb)
• 12 cassette tapes in covers.
(The ones I picked at the second hand store are in clear covers so they let the most light out)
• Hard plastic glue (transparent)
• Universal contact glue/Bond glue.
• A screw driver.
Step 2 Making
The IKEA lamp base comes with a 30cm or so high metal tube that needs to be removed.
First unscrews it from the base. That's the easy part.
Next you will need to remove the light bulb adapter from the top of the metal tube.
It is glued in place but with a little help from a flat head screw driver and a bit of wiggling with a good hand grip it will come off.
Disconnect the wires from the bulb adapter (Take note of which wire goes where) and then you can remove the metal tube.
Reconnect the Bulb adapter.
Using Contact/bonding glue attach the bulb adaptor really well to the base.
Step 3 The cassettes
On a flat surface I first stacked up the cassettes without glue to see what they looked like.
Don't forget to give the cassettes and covers a good clean/dusting. It impossible after you add glue.
After deciding on the layout I set them apart in 3 sets of 4 cassettes.
At this stage you can also add a dab of glue to the hinge to keep them shut.
Glue the first layer (4 cassettes) with the hard plastic glue to each other. Using the IKEA base as a guide to keep everything square.
Then the second and third in an overlapping style. see pic
Finally when all the Cassettes are glued and dry I attached them to the base using plenty of Universal contact/Bond glue.
And that's it. The IKEA base comes already fitted with a nice on/off switch and a plug.
ENJOY
There are so many different glues out there, but i think a general purpose glue should also work fine. Just check what materials it is suitable for. Hope this helps
I followed the instructions. Ikea did not have the model number or size listed for base. I got the closest one. It was a 14 base. Worked fine.
Hardest part was getting the metal tube from the base (what was described as the easy part)......lol.......and I couldnt glue the light fixture in place well. So it is looser than I'd like inside.
Make your own. Kids songs, rock and roll, country, classical, motivational, gospel, .........any theme that fits you!
Strange you would think ikea stuff would be fairly standard across the globe.
Dunedin, New Zealand, lovely spot, happy memories there pre xmas festivities 2009. :) Success
As for heat, even after a few hours with this bulb it still feels cool on the inside of the tapes which surprised me. The narrow profile of the bulb probably helps.
