That's where Cast Thermite comes in. And the best part is, If you have some thermite on hand already, it's pretty easy to make! If you don't, never fear, for I will be starting at the beginning with nothing but the raw materials.
Remove these ads by
Signing UpStep 1Obtain the Materials
Now that that's out of the way, onto the fun part. The preparations!
The first thing to do is understand what thermite is made up of. Most commonly, homemade thermite is made up of iron oxide (rust) and granule or powered aluminum. When mixed together, these two metals create an incendiary capable of reaching temperatures of several thousand degrees. For more info check thermite's Wiki page. So:
What we need:
- Fine (0000) Steel Wool (not pictured)
- Aluminum
- Some kind of scale
- Plaster of Paris
- Handling materials (spoon, cup, paper, coffee can...)
- Some kind of mold to cast your thermite in
- Steel Wool
- Aluminum
- Scale/Plaster of Paris
- The Mold
Finally, you say. I've got everything you told me to get. Let's get started!
![How to Make a Fire Wire [Easy Fireworks]](http://img.instructables.com/files/deriv/FGB/4O3D/GWKKMGC7/FGB4O3DGWKKMGC7.SQUARE.jpg)
a) More work than it's worth.
b) Waste of an etch-a-sketch (they're not hard to fix)
All due respect, from personal experience doing this countless times, the materials definitely do combust ferociously. Simply put, you're incorrect. But don't take my word for it. Try it for yourself. :)
