3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cast Thermite
Step 3Refining Part 2
Refining Part 2
This next step is not necessarily required, depending on how fine your burnt steel wool, (now called iron oxide), is, but as I am something of a perfectionist I like my chemicals to be as fine as I can get them.
If you have a ball mill similar to the one below, this step will be simple for you. Toss your iron oxide into whatever container you use along with some grinding media and away you go!
If, on the other hand, you do not have a fancy shmancy ball mill, no big deal. A Mortar and Pestle will get the job done just as well.
So will a coffee can full of iron oxide and some grinding media. All you have to do is shake it... A lot. By grinding media I mean something small, hard, and round, that is capable of breaking up the particles that you are trying to refine.
So, if you opted to go through with this step, use one of these methods to crush the iron oxide. Unless you get it ground to a powder it clumps together a little bit, but don't worry about it, because that's about the consistency that I use it at, and it still works. It doesn't have to be perfect by a long shot, just do what you can and move on.
6 comments
Jun 29, 2011. 12:34 PMramkanwar55 says:
you could just use the stone age method of using a file on an iron screw/nail
Oct 24, 2010. 4:31 AMbio-logical says:
when i try to refine mine i use a sifter and the iron oxide doesn't seem to be anywhere but the outside of the strand because i keep seeing silver. any help
Mar 11, 2011. 3:46 AMcodongolev says:
you could probably use finer steel wool, and maybe try burning it with a hacked lighter to keep the reaction going.
Jul 12, 2010. 8:24 AMmattbomb says:
would mare-balls(the glass ones) would they work or just break
May 29, 2010. 9:19 PM67firebird says:
Ingenious ball mill------did you design/build it yourself?
Are plans or details available?
The only time I ever made thermite, it burnt through an iron crucible, through
an asbestos pad, through a coffee can full of water, another asbestos pad,
through the iron base of a ring stand,
and then through the science teacher's lab table, through a couple of shelves
and misc., and into the floor, before it went out.  I seem to remember some
kind of chlorate in it, maybe potassium chlorate?  It was spectacular, but I
caught a lot of heat over it (all puns intended).
Sep 8, 2009. 1:38 PMloopycar27 says:
if this whole thing works i love you
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:Zlwilly(Lace Williamson)
What's to say? I have a deep passion for all things electrical and mechanical, and the more of it I can get my hands on, the happier I am!
