Why tin? Tin melts very low in temperature. Basically, the lowest melting point of any useful, non-toxic metal(*). It melts around 500 degrees, is very castable, and looks brilliant. There's only one real good reason not to use it: it's relatively expensive. I got mine from Rotometals in San Leandro for around $10/lb. Its density is similar to lead.
(*) Tin may cause some illnesses, this is debated. work it as if it does. Do your own research.
Remove these ads by
Signing UpStep 1Safety!
Long story:
Tin is cooler than basically any other metal you'll ever work with, that means that if you screw up, you'll probably survive and have to deal with the hospital, burn wards, grievous scars, and potentially being disfigured or crippled for the rest of your life. Always have full face protection, arm and body protection that buttons at the neck, and closed toe shoes.
Respirator might not be a bad idea either, as who knows what those stray 1 or 2 percent are in the 98-99% pure Tin. I suggest doing things outside.
Pretty much, dress like you're welding, only with a clear visor. Check out my fashion statement picture for an idea. Do any of this at your own risk, perform your own safety assessments. Only you are responsible for the consequences of your actions.
Well, I change that. I didn't completely melt the wax out of the mold and then kaboom-fizzle-burn but that is about it. I still use plaster for casting tin.
That boiling is the release of water that is still in the mold. Fine if you are using time because of the low melting point. If you were to have applied this to lead or a lead tin mixture, you would have had a small explosion and would have been nursing burns from 550 degree to 650 degree molten metal.
I would highly recommend either the use of pre-formed molds from a hobby shop or the use of casting sands for custom molds. If one were to use plaster for a casting job, it would be a good idea to fire it in a small kiln rather than an oven. Better yet, get a DIY Silicon mold kit that can take the high temps and be used repeatedly.
Good points on the safety equipment. Would recommend adding an exhaust fan or opening the garage door for the fumes.
For my molds, I heated the plaster for 3 hours at 400 degrees to reduce the odds of it cracking and spewing everywhere. Dangerous, I know, but I was using what I had. I've edited the mold section to reflect the danger of plaster molds.
I'm going to change some wording about my pot. Could you look through and see if anything in particular needs changing? If it is horribly wrong all over, just tell me, and I'll take it down, under the condition that you do an instructable over casting.
