3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cast Tin!
Step 3Melt that tin: Get ready
 For a "crucible", I picked up a used stainless steel pan from Urban Ore for 71 cents. It was made of very thick stainless steel, so I specifically chose it over Cast Iron, which is what is normally recommended. If you've got time and the money, get yourself a small crucible, and don't mess around with this stuff.
For a "furnace", I used an old campstove I found hanging around. It was propane fired, and I've got propane around. I'd suggest doing this in a place with adequate ventilation. Outside worked for me, but I still threw on the respirator, just because it is fun.
For temperature control, I used a Fluke IR thermometer, which was reasonably accurate, even with the shiny surface of the tin. I also took a lot of readings of temperatures of the pot and the mold to make sure the pot wouldn't melt and that the mold was appropriately hot.
At this point, don your safety gear, just because. Fire up the stove, throw a blingot into the crucible, and let it heat up over a low-to-medium heat. It'll start to puddle shortly. Once it puddles, you can dial up the heat, and add more tin. It's a lot like melting snow for water, if you've ever been snow camping.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:seraphus
Just your average robotics and fire arts tinkerer.
