The effect is of a hand that's emerging from the wall to hold the item. It's simple and sculptural, and while the approach was perfect for this item, one should be able to use a similar approach for a range of other items.
This also serves as something of a keepsake since the hand cast is that of my dad, which is also fitting since he grew up on a farm, as did generations before.
The challenges were (1) casting it such that the hole matched the one needed to hold the rake, and (2) attaching the plaster hand to the wall in a way that revealed no hooks or other fasteners.
The materials are inexpensive and readily available. The mounting method was very "invasive," but it produced the effect desired. (We also don't plan on taking this down until we move.)
The rake is not affected, which was one of the requirements we had at the outset.
And truth-be-told, we didn't realize that the slope of the rake was just about the same as the slope of the ceiling until it was mounted.
Remove these ads by
Signing UpStep 1Cast the plaster hand, unmold it, clean it up, and seal it.
My dad, whose hand we cast, held a piece of PVC in his hand. (Note that the angle, which was a guess, needed to be pretty close in order for an item of this size to be held without creating force that would pull the hand off the wall.)
After unmolding, it was easy to remove the PVC.
Following the directions that came with the casting material, we let it dry and then cleaned up the cast hand. This included filling some of the surface air holes with leftover casting material. We also sanded the surface with fine sandpaper in places to achieve a smooth surface.
We then spray painted it white (gloss) to ensure a uniform appearance and protect the soft plaster.
15
comments
Add Comment
rimar2000
says:
rimar2000
says:
porcupinemamma
says:
rimar2000
says:
porcupinemamma
says:
kelseymh
says:
Ninzerbean
says:
Add Comment
