3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cast plaster hand mounted to wall holds item for display.
Step 2The rod and hollow wall anchors need to match.
Here's where we're headed: A threaded rod is inserted into a hole drilled through the hand. The hole emerges at the inside of the palm. The threaded rod screws into a hollow wall anchor inserted into the wall. The hand is inserted onto the rod and held in place with a spacer and nut. The item, in this case a rake with a tapered handle, is inserted carefully.
As shown below, the threaded rod has to fit the hollow wall anchors, both in diameter and threads per inch. Labels on each make this straightforward; the items are available from hardware stores small and large.
Instructions on the box for the anchors explain attaching this to your wall. (Pick the place carefully; it will be there for a long while.)
The strews that come with the hollow wall anchors aren't used.
A hole is drilled in the hand using a very long bit. We used a 12" long 1/4" bit. That was longer than needed, but we had it on hand (so to speak) and the length made it easier to see if we were perpendicular to the base.
We were lucky because it ended up being close.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:leewright
