I'll show pictures of the 3D printed molds I've used but you can also cast into molds made from many other materials. I have had good results casting polyurethane foam into silicone molds as well. And I would expect that molds of plaster, wood, or most other nonreactive materials would also work, with proper mold release.
Note that if you are going to use a silicone, or other rubber mold, you will need to be sure to use a "mother" mold, which is an outer mold that is stiff, unlike the stretchy rubber. Expanding foam does just that, it expands, and it will try to push the mold pieces apart, or deform the mold if it is not rigid enough. It is common to use plaster of paris for the outer mold, and I have also successfully used thermoplastic in sheet form.
"Submitted by Ace Monster Toys for the Instructables Sponsorship Program"
Remove these ads by
Signing UpStep 1: Tools and Materials
- kitchen scale (but use a dedicated one or put the whole thing in a clear plastic bag in case of spills)
- small containers. paper or plastic cups work well; empty pill bottles are great but for the small neck kind you must cut this off with a knife
- drill with a stirring attachment
- stirrers - plastic spoons, popsicle sticks, single-use chopsticks all work well
- paper towels
- clamps (more on this later)
- scraper (not shown)
- mold release. I tried a couple things and Turtle Wax worked pretty well for the ABS-like plastic molds. Different mold releases may be better for other mold materials. (When I cast into silicone molds I did not use any release as silicone rarely needs it.)
- paintbrush if your release doesn't come as a spray
Visit Our Store »
Go Pro Today »
Gone to my Blog:
http://faz-voce-mesmo.blogspot.pt/2012/12/avancos-contra-o-cancro-sobrevivencia.html
Good tip on chilling the foam components before mixing.
What stirring attachment do you use?
